HPE StorageWrks DAT 160 USB Int Dr
Quicklinx: 5LH7WS00 Mfr#: Q1580A
Protect your small or medium sized business, remote office or workgroup with the HP StorageWorks DAT 160 USB Tape Drive offering the highest capacity and performance with the ability to store up to 160GB of compressed data on a single cartridge at speeds of up to 50GB/hr (assuming 2:1 data compression). Low ongoing cost of ownership is provided through low-cost, durable DAT media and a two generation backward compatibility with DAT 72 and DAT 40 which delivers a seamless upgrade path from older drives. The DAT 160 USB Tape Drive is available with a USB 2.0 interface for low-cost, universal plug-and-play connectivity in a choice of models including internal (which also fits in the 1U Rack-Mount kit) and external making it compatible with virtually any server environment.
HPE StorageWorks DAT 160 USB Internal Tape Drive - tape drive - DAT - USB 2.0
Tape drive
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
USB 2.0
14.5 cm x 18.3 cm x 4 cm
1.2 kg
Storage Removable
DAT - 5.25" x 1/2H
Storage Removable Capacity
80 GB (native) / 160 GB (compressed)
Supported Tape Cartridges (Read and Write)
DDS-4, DAT-72, DAT-160
Data Transfer Rate (native)
6.9 MBps
Data Transfer Rate (compressed)
13.8 MBps (49.3 GBph)
Linux, Microsoft Windows
Microsoft Certification
Compatible with Windows 7
Workstation xw4600; ProLiant DL370 G6, ML110 G6, ML110 G7, ML150 G5, ML150 G6, ML310 G5p, ML330 G6, ML350 G6, ML370 G6; StorageWorks All-in-One Storage System 1200r 12, 1200r 2.4TB, 1200r 3.6TB, 1200r 3TB, 1200r 5.4TB, 1200r 6TB, 1200r 9TB, 400r 1.2TB, 400r 1TB, 400r 2TB, 400t 1TB, 400t 584
Tape drive - DAT
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
USB 2.0
14.5 cm
18.3 cm
4 cm
1.2 kg
Storage Removable
DAT - 5.25" x 1/2H
Recording Standard
DAT 160
6.9 MBps
Average Seek / Access Time
50 sec
Buffer Size
16 MB
1 x USB 2.0
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
Cleaning cartridge
MTBF
125,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, CISPR 22, CSA 22.2 No. 60950, FCC
Software Included
HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
5 °C
20 - 80%
HP Workstation xw4400, xw4550, xw4600, xw6600, xw8600, xw9400 , HPE ProLiant DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G5 Storage Server 1.16TB SAS Model, DL380 G5 Storage Server 1.2TB SCSI Model, DL380 G5 Storage Server 1.8TB SAS Model, DL380 G5 Storage Server 2.7TB SAS Model, DL380 G5 Storage Server 2TB SATA Model, DL380 G5 Storage Server 3.6TB SAS Model, DL380 G5 Storage Server 4.5TB SATA Model, DL380 G5 Storage Server 6TB SATA Model, DL380 G5 Storage Server 9TB SATA Model, DL380 G5 Storage Server SAN Storage Model, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, DL585 G2 Storage Server, ML110 G4, ML110 G5, ML110 G5 1TB Storage Server, ML110 G5 2TB Storage Server, ML110 G5 320GB Storage Server, ML110 G5 584GB Storage Server, ML110 G6, ML110 G7, ML115, ML115 G1, ML115 G5, ML150 G5, ML150 G5 Base, ML150 G5 Performance, ML150 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G4, ML310 G4 1TB Storage Server, ML310 G4 2TB Storage Server, ML310 G4 3TB Storage Server, ML310 G4 584 GB SAS Storage, ML310 G4 640 GB Storage Server, ML310 G5, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G5 High Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry , HPE StorageWorks All-in-One Storage System 1200 1.7TB SAS Model, 1200 3.6TB SAS Model, 1200 3TB SATA Model, 1200 6TB SATA Model, 1200 9TB SATA Model, 1200r 12TB SATA Model, 1200r 2.4TB SAS Model, 1200r 3.6TB SAS Model, 1200r 3TB SATA Model, 1200r 5.4TB SAS Model, 1200r 6TB SATA Model, 1200r 9TB SATA Model, 400 1TB Model, 400r 1.2TB SAS Model, 400r 1TB SATA Model, 400r 2TB SATA Model, 400t 1TB SATA Model, 400t 584GB SAS Model, 600 1.5TB Model, 600 1.8TB SAS Model, 600 3.0TB Model, 600 876GB SAS Model
