Protect your small or medium-sized business, remote office or workgroup with HP DAT Tape Drives offering the ability to store up to 160 GB of compressed data on a single cartridge at speeds of up to 49.3 GB/hr (assuming 2:1 data compression). Low ongoing cost of ownership is provided through low-cost, durable DAT media and backward compatibility which delivers a seamless upgrade path from older drives. HP DAT Tape Drives are now onlt available with 160 GB of capacity with interface types, SCSI, SAS and USB, making them compatible with virtually any server environment. DAT Tape Drives come complete with data and cleaning cartridge, the option to download Yosemite Server Backup Basic backup and recovery software (for a single Windows or Linux server), and HP Library and Tape Tools.
High Performance Backup Solution That Fits Most Environments
Provides a balance of price and performance for small and medium business environments and enterprise workgroups. HP DAT 160 Tape Drives can store up to 160 GB on a single cartridge, backing up to 49.3 GB/hr on a single DAT 160 cartridge in around four hours.Available as external or internal models to fit servers, workstations, and rack-mount kits. SAS, SCSI or USB 2.0 interfaces for universal plug and play.Visit us on the web for the latest information on HP Backup Compatibility.Helps prevent unauthorized access of tape media (lost or stolen cartridges). Tape drive based encryption avoids performance degradation associated with host based encryption. -
Reduce Your Backup Costs
Low-cost is driven by low-cost durable DAT media, and ongoing low-cost of ownership.As the most popular backup technology of all time, DAT provides investment protection through a proven track record of reliability and backwards compatibility. -
Complete Backup Solution
Restores your entire ProLiant system at the touch of a button without the need for system disks or software CDs. Visit HP One-Button Disaster Recovery (OBDR) Solution for the latest information.Provides a complete, easy-to-use backup solution that includes DAT media, cleaning cartridge, and the option to download Yosemite Server Backup Basic Software, to allow users to protect their data without any additional purchases.
- HPE StorageWorks DAT 160 USB External Tape Drive - tape drive - DAT - USB 2.0
- Tape drive
- Recording Standard
- DAT-160
- Enclosure Type
- External
- Interface Type
- USB 2.0
- 18.1 cm x 23.6 cm x 6.7 cm
- 2.3 kg
- Storage Removable
- DAT
- Storage Removable Capacity
- 80 GB (native) / 160 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- DDS-4, DAT-72, DAT-160
- Data Transfer Rate (native)
- 6.9 MBps
- Data Transfer Rate (compressed)
- 13.8 MBps (49.3 GBph)
- Power
- AC 120/230 V (50/60 Hz)
- OS Required
- Linux, Microsoft Windows
- Microsoft Certification
- Compatible with Windows 7
- Designed For
- Workstation xw4600; ProLiant DL160 G5, DL160 G5p, DL160 G6, DL165 G5p, DL165 G6, DL180 G6, DL320 G6, DL360 G6, DL370 G6, DL380 G6, DL385 G5, DL385 G5p, DL385 G6, DL585 G5, DL585 G6, DL785 G6, ML150 G5, ML150 G6, ML310 G5p, ML330 G6, ML350 G6, ML370 G6
- Tape drive - DAT
- DAT-160
- Enclosure Type
- External
- Interface Type
- USB 2.0
- 18.1 cm
- 23.6 cm
- 6.7 cm
- 2.3 kg
Storage Removable
- DAT
- Capacity
- DAT 160
- 6.9 MBps
- Average Seek / Access Time
- 50 sec
- Buffer Size
- 16 MB
- 1 x USB 2.0 - 4 pin USB Type B
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- MTBF
- 125,000 hour(s)
- TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, CISPR 22, CSA 22.2 No. 60950, FCC
- Power supply
- Voltage Required
- 10.3 watt
- Software Included
- HP StorageWorks Library and Tape Tools, HP StorageWorks Data Protector Express Single Server
- OS Required
- 5 °C
- 40 °C
- 20 - 80%
- Designed For
- HP Workstation xw4600 , HPE ProLiant DL120 G5, DL160 G5 Special Server, DL160 G5p, DL160 G5p Special Server, DL160 G6, DL160 G6 Special Server, DL165 G5 Special Server, DL165 G5p, DL165 G5p Base, DL165 G5p Efficiency, DL165 G5p Entry, DL165 G5p Performance, DL165 G6, DL180 G5 Special Server, DL180 G6, DL180 G6 Special Server, DL185 G5 12TB SATA Storage Server, DL185 G5 2.4TB SAS Storage Server, DL185 G5 4TB SATA Storage Server, DL185 G5 6TB SATA Storage Server, DL185 G5 9TB SATA Storage Server, DL185 G5 Base SAS Storage Server, DL185 G5 Base SATA Storage Server, DL185 G5 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL365 G5 Base, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL380 G5 High Efficiency, DL380 G5 Storage Server 2.7TB SAS Model, DL380 G5 Storage Server 6TB SATA Model, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL385 G5, DL385 G5 Carrier-Grade, DL385 G5 Entry, DL385 G5p, DL385 G5p Base, DL385 G5p Entry, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML115 G1, ML150 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry , HPE StorageWorks All-in-One Storage System 1200r 12TB SATA Model, 1200r 2.4TB SAS Model, 1200r 3.6TB SAS Model, 1200r 3TB SATA Model, 1200r 5.4TB SAS Model, 1200r 6TB SATA Model, 1200r 9TB SATA Model, 400r 1.2TB SAS Model, 400r 1TB SATA Model, 400r 2TB SATA Model, 400t 1TB SATA Model, 400t 584GB SAS Model
