Compatible and optimized for HP SS03050XL.
The battery utilizes high quality cells for higher performance, longer life and more reliability. The built-in protection circuit ensures both safety, stability, fast charging and low power consumption for your device.
Extended battery life
With a capacity of 4.33 Ah and 50 Wh, this HP notebook battery ensures your device stays powered longer, enabling you to work or play without constant recharges. -
Reliable performance
Designed with high-quality lithium-ion technology, the HP SS03050XL-PL battery offers stable and efficient power to your notebook, ensuring reliable performance when you need it most.
- HP SS03050XL-PL - laptop battery - Li-Ion - 4.33 Ah - 50 Wh
- Laptop battery
- Battery
- Lithium Ion 3-cell - 4.33 Ah - 50 Wh
- Designed For
- EliteBook 735 G5 Notebook, 745 G5 Notebook, 840 G5 Notebook; Mobile Thin Client mt44, mt45; ZBook 14u G5 Mobile Workstation
- Laptop battery
- Technology
- 3-cell Lithium Ion
- Capacity
- 4.33 Ah - 50 Wh
- Designed For
- HP EliteBook 735 G5 Notebook, 745 G5 Notebook, 840 G5 Notebook , HP Mobile Thin Client mt44, mt45 , HP ZBook 14u G5 Mobile Workstation
