The HP Smart Array P212 is HP's entry level PCI Express (PCIe) Serial Attached SCSI (SAS) RAID controller. The low profile, half height card has 8 ports. The P212 is ideal for RAID 0, 1, 1+0.
- HP Smart Array P212/Zero Memory Controller - storage controller (RAID) - SATA 3Gb/s / SAS 6Gb/s - PCIe 2.0 x8
- Storage controller (RAID) - plug-in card - low profile
- Interface Type
- PCIe 2.0 x8
- Interface
- Data Transfer Rate
- 600 MBps
- Supported Devices
- Hard drive, disk array (RAID)
- Max Storage Devices Qty
- 54
- RAID Level
- RAID 0, RAID 1, RAID 10
- 5.7 cm x 24.1 cm x 19.1 cm
- Designed For
- LTO-5 Ultrium; ProLiant DL120 G7, DL165 G7, DL360 G7, DL370 G6, ML110 G7, SL165s G7; StorageWorks MSL2024, MSL4048, MSL8096, X1400 G2, X1500 G2, X1600, X1600 G2, X1800, X1800 G2, X3400 G2, X3800 G2; StorageWorks 1/8 G2 Tape Autoloader; LTO-5 Ultrium; StorageWorks Rack-Mount Kit Ultrium 1760
- Host Bus
- PCIe 2.0 x8
Storage Controller
- Interface
- 600 MBps
- Supported Devices
- 54
- RAID Level
- 1 x SATA 3Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane SAS (SFF-8087) ( internal ) , 1 x SATA 3Gb/s / SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) ( external )
- Compatible Slots
- 1 x PCI Express 2.0 x8
- 5.7 cm
- 24.1 cm
- 19.1 cm
- Designed For
- HP LTO-5 Ultrium 3000 SAS Internal Tape Drive , HP ProLiant DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL170h G6, DL180 G6, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL4x170h G6, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6 Entry, ML350 G6 Performance, ML370 G6 Base, ML370 G6 Entry, SL160z G6, SL165s G7, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6 , HP StorageWorks DAT 320 SAS Internal Tape Drive, MSL2024 Ultrium 3000, MSL4048 Ultrium 3000, MSL8096 Ultrium 3000 , HP StorageWorks 1/8 G2 Tape Autoloader Ultrium 3000 , HP StorageWorks LTO-5 Ultrium 3000 SAS External Tape Drive, 3000 SAS Internal Tape Drive, 3280 , HP StorageWorks Network Storage Gateway X3400, X3400 G2, X3800, X3800 G2 , HP StorageWorks Network Storage System X1400 2TB SATA Model, X1400 4TB SATA Model, X1400 G2, X1500 G2, X1600, X1600 12TB SATA Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1600 G2, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model, X1800 G2 , HP StorageWorks Rack-Mount Kit Ultrium 1760 Drive
Options (5)
| HP External Mini SAS 2M Cable | Out of Stock | £97.13 |
| HP 256MB P-Series Cache Upgrade | Out of Stock | £65.85 |
| HP Mini-SAS Cable for LTO Int | Out of Stock | £78.58 |
| HP Smart Array Mini SAS to Mini SAS 28" Cable Assemb | Out of Stock | £31.90 |
| HP CABLE MINI-SAS/SFF8484 18IN F/SMART ARRAY P41X | Out of Stock | £31.43 |
