HPE Server Console Switch 1x4 - KVM switch - 4 ports - rack-mountable
Quicklinx: 4XDWWS00 Mfr#: AF611A
Looking for a simple and intuitive solution that allows you to access and manage servers in your data center? HP KVM Analog Console Switches allow you to view and manage up to 256 rackmount servers in your data center through a single user interface. HP KVM Analog Console Switches utilize a local On-Screen Display (OSD) interface, accessed through a rack console such as the HP LCD8500, that provides intuitive menus for accessing each attached server or serial managed device. HP G3 KVM Analog Console Switches support an optional USB Remote Access Key that allow you to upgrade to KVM-over-IP functionality, providing remote access and management via the On-Board Web Interface (OBWI). HP KVM Analog Console Switches are available in 4, 8 and 16-Port models. Standard rack mounting of the KVM Console Switch will share 1U (1.75-inch) of front panel rack space with the rack console. However, each model can also be mounted in a "zero U" profile by mounting in the side rails of the rack.
  • ATEN G2 KVM Switches are Suitable for Installation in Most IT Environments
    ATEN G2 KVM Switches for HPE are qualified for integration into HPE racks using HPE Factory Integration Services.Mounting Hardware is included for easy installation into HPE G2 Advanced and Enterprise Racks.Attachable foot pads are included for deployment of the switch in a desktop configuration.
  • ATEN G2 KVM Switches for HPE Support Three Different Methods to Select Your Target Device
    ATEN G2 KVM Switches for HPE feature front side push-button selection with LED indicators allow for direct selection of the target device.Keyboard hot-key support allows target device selection when the switch is inaccessible inside the rack.A menu-driven multi-lingual OSD (On Screen Display) feature allows for target device selection through a graphical interface on the connected monitor or KVM console.
  • ATEN G2 KVM Switches for HPE Allow Access to up to 256 Servers Through a Single KVM Installation
    ATEN G2 KVM Switches for HPE come in 4, 8, and 16 port models to support up to 16, 64, and 256 devices respectively through two level tiering/cascade technology.Switch connectivity to individual servers is supported through interface adapter cable options that support servers using USB with both VGA and Display Port video connections.
  • ATEN G2 KVM Switches for HPE Provide Security Features to Prevent Unauthorized Users
    ATEN G2 KVM Switches for HPE feature two level password security so only authorized users view and control connected devices.ATEN G2 KVM Switches for HPE support up to four separate user profiles and an administrator profile.
KVM switch - 4 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user
33 cm x 10 cm x 4.4 cm
3.1 kg
HPE 10XXX G2, 600, 800; Advanced Series Racks 42U 600; ProLiant BL460c Gen8, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 G6, DL380 Gen9, DL60 Gen9, DL80 Gen9, e2000 G6, ML110 Gen9, ML150 Gen9, ML350 Gen9, ML350p Gen8; Rack
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
2048 x 1536
4 x KVM , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15 , 3 x USB 2.0 Type A
Internal power supply
2 x keyboard / mouse / video cable - 1.8 m
Rack Mounting Kit
Included
DDC-2B
33 cm
10 cm
4.4 cm
3.1 kg
10 °C
20 - 85%
HPE 10642 G2 1200mm deep Shock Rack, 10647 G2 1200mm deep Shock Rack, 600mm x 1075mm Advanced Pallet Rack, 600mm x 1075mm Advanced Shock Rack, 600mm x 1075mm Enterprise Crate Rack, 600mm x 1075mm Enterprise Pallet Rack, 600mm x 1075mm Enterprise Shock Rack, 600mm x 1200mm Advanced Pallet Rack, 600mm x 1200mm Advanced Shock Rack, 600mm x 1200mm Enterprise Air Duct Rack, 600mm x 1200mm Enterprise Pallet Rack, 600mm x 1200mm Enterprise Shock Network Rack, 600mm x 1200mm Enterprise Shock Rack, 600mm x 1200mm Grey Enterprise Air Duct Rack, 600mm x 1200mm Grey Enterprise Shock Rack, 600mm x 1200mm Network Advanced Shock Rack, 800mm x 1075mm Enterprise Pallet Rack, 800mm x 1075mm Enterprise Shock Rack, 800mm x 1200mm Advanced Pallet Rack, 800mm x 1200mm Advanced Shock Rack, 800mm x 1200mm Enterprise Pallet Rack, 800mm x 1200mm Enterprise Shock Network Rack, 800mm x 1200mm Enterprise Shock Rack, 800mm x 1200mm Grey Enterprise Shock Network Rack, 800mm x 1200mm Grey Enterprise Shock Rack, 800mm x 1200mm Network Advanced Shock Rack , HPE Advanced Series Racks 42U 600mm x 1075mm Kitted Advanced Pallet Rack with Side Panels and Baying, 42U 600mm x 1075mm Kitted Advanced Shock Rack with Side Panels and Baying , HPE ProLiant BL460c Gen8, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8 v2 Entry, DL360 Gen9 Performance, DL360p Gen8, DL360p Gen8 CMS, DL380 G6, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, e2000 G6, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350p Gen8 , HPE Rack
