HP ScanJet Pro 4500 fn1 Document Scanner
Quicklinx: BYHVWS00 Mfr#: L2749A#B19
Get fast two-sided scanning with a network scanner recommended for 4,000 sheets per day. Digital sending is easy from the touchscreen via wireless network or Wi-Fi Direct. Send scans to mobile devices using the HP JetAdvantage Capture app.
HP Scanjet Pro 4500 fn1 - document scanner - desktop - USB 3.0, Gigabit LAN, Wi-Fi(n)
Document scanner - desktop
Interface Type
Scanning Sensor Type
CMOS / CIS
Light Source
LED
Additional Functions
Email, scan to cloud
Max Supported Document Size
216 x 3100 mm
English, German, French, Italian, Spanish / Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 3100 mm
Automatic Duplexing
Supported Document Type
Business card, labels, photo, envelope, post card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
4000 scans per day
Microsoft Windows 7 or later, Apple MacOS X 10.11
52 cm x 38.7 cm x 14.5 cm
5.98 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
216 x 3100 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
30 ppm , 60 ppm - duplex
Scanner Features
2.8" touch screen LCD display
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 3100 mm
Supported Document Size Details
ADF - up to 216 x 3100 mm , Flatbed - up to 216 x 297 mm
Automatic
50 sheets
Interfaces Details
USB 3.0 , Gigabit LAN
1 x USB cable
CSA, SASO, EMC, UL 60950-1 Second Edition, EAC, IEC 60950-1:2005, EN60950-1:2006 +A11+A1+A12, TER, EN 61000-3-3:2013, CISPR 24:2010, PVOC, CISPR 22:2008, EN 61000-3-2:2014
ENERGY STAR Certified
External power adapter
Power Consumption Stand by
6.11 Watt
Power Consumption Sleep
1.35 Watt
Software Included
Drivers & Utilities, Cardiris, Kofax VirtualReScan, I.R.I.S. OCR, Nuance PaperPort, HP Scan, HP Scanner Tools Utility
System Requirements Details
Windows 7 or later - 2 GHz - RAM 2 GB - HD 170 MB , MacOS X 10.11 - RAM 1 GB
52 cm
38.7 cm
14.5 cm
5.98 kg
Shipping Width
64 cm
Shipping Depth
48.6 cm
Shipping Height
24.5 cm
Shipping Weight
7.9 kg
Limited warranty - 1 year
10 °C
35 °C
15 - 80% (non-condensing)
BYHV HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £162.11
