Manage all your office scanning – single or double-sided documents, bound reports, business cards, photos and even slides and negatives – from one versatile machine. Boost productivity with document enhancement and programmable shortcuts.
Capture everything from single receipts to stacks of papers with this ultra-versatile scanner
Put an advanced document capture device at the heart of your business and get versatile image scanning from the same machine. Scan it all – stacks of papers, bound or stapled documents, business cards, photos, 35 mm slides and negatives. -
Streamline your scanning processes with easy shortcuts and automatic image enhancement features
Complete common tasks more efficiently with one-touch shortcuts. Use HP scanning technology to automatically deskew, crop and rotate digitised files. Choose colour-drop-out to improve OCR accuracy when turning documents into editable digital files. -
Scan multipage documents quickly and reliably with the duplex automatic document feeder
Boost office productivity with easy unattended document capture using the 50-sheet duplex automatic document feeder. Scan at up to 15 ppm/6 ipm. Preview, edit and adjust scans using HP Scanning Software. ISIS , TWAIN and WIA drivers included.
- HP ScanJet N6310 Document Flatbed Scanner - flatbed scanner - USB 2.0
- Flatbed scanner
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- 220 x 356 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Optical Resolution
- 2400 dpi x 2400 dpi
- Scan Speed
- 15 ppm
- Max Document Size
- 216 mm x 292 mm
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.5 or later, Apple MacOS X 10.4.11
- Microsoft Certification
- Certified for Windows Vista
- 50.2 cm x 41.5 cm x 16.8 cm
- 6.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Flatbed scanner
- Interface Type
- USB 2.0
- 220 x 356 mm
Scanner
- Input Type
- Colour Depth
- 48-bit colour
- CCD
- Scan Speed
- 15 ppm
- Control Panel Buttons Functions
- Scan, copy, cancel, setup
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 292 mm
- Supported Document Size Details
- ADF - up to 220 x 356 mm , Flatbed
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- Transparency adaptor
- Cables Included
- 1 x USB cable
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Drivers & Utilities, Presto! PageManager, Readiris Pro, ScanSoft PaperPort, Presto! BizCard
- OS Required
- Additional Requirements
- CD-ROM, SVGA monitor
- System Requirements Details
- Windows XP Home/Pro - 1.3 GHz - RAM 512 MB - HD 450 MB , Windows Vista - 1.3 GHz - RAM 1 GB - HD 450 MB , Windows 2000 - 800 MHz - RAM 256 MB - HD 450 MB
- 50.2 cm
- 41.5 cm
- 16.8 cm
- 6.7 kg
- 10 °C
- 35 °C
- 15 - 80%
