HP Scanjet 5590P
HP Scanjet 5590P Digitaler Flachbettscanner
HP Scanjet 5590P
Quicklinx: 3J5WWS00 Mfr#: L1912A#ABU
Fast, professional-quality scanning solution with 2400 dpi / 48-bit performance and preview scans in under 7 seconds. Included transparency adapter and optional 50 page duplex automatic document feeder (ADF) let you scan whatever you want.
HP ScanJet 5590p Digital Flatbed Scanner - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 297 mm
English / United Kingdom
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Transparencies, plain paper, slides, film
Document Feeder Type
Manual
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.1.5, Apple MacOS X 10.2 or later
Microsoft Certification
Certified for Windows Vista
48.8 cm x 34 cm x 8.3 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Control Panel Buttons Functions
Scan, copy, email, power save, cancel, save document
Scanner Speed Details
28 sec/scan - photo - colour - 10x15cm , 31 sec/scan - black & white , 48 sec/scan - OCR - A4
TWAIN
Media Handling
Max Document Size
216 mm x 297 mm
Manual
Interfaces Details
USB 2.0 - Type B
Film adaptor
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, EMC
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
36 Watt
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM, SVGA monitor
System Requirements Details
Windows 98/98SE/2000/ME/XP - Celeron RAM 64 MB - HD 225 MB , MacOS X - RAM 128 MB - HD 240 MB
48.8 cm
34 cm
8.3 cm
3.4 kg
Limited warranty - 1 year
5 °C
5 - 90%
