HPE RDX500 EXT REMOV DISK B"UP SYS
Quicklinx: 71G7WS00 Mfr#: AJ935A
HP RDX+ Removable Disk Backup System is a rugged, removable, easy-to-use, cost effective, disk backup solution for servers and workstations. It is the ideal backup solution for remote locations or small to medium businesses with little or no IT resources that are in less than ideal locations such as a busy office, field base sites, or business that require mobility. It is perfect for these environments due to its ruggedness and the fact that it only requires a USB connection, no separate power source/cord required. Protect your entire system with the "hands-free" HP RDX Continuous Data Protection Software. Reduce cost of ownership with long lasting removable disk cartridges and a forward and backward compatible docking station. The HP RDX+ Removable Disk Backup System offers fast disk-based performance with the ability to store 500 GB, 1 TB or 2 TB of data on a single removable disk cartridge at speeds of up to 360 GB/hr.
  • Backup and Recovery Made Easy
    The HPE RDX Removable Disk Backup System delivers a rugged, portable cartridge design protecting hard drive information and making transporting data between locations easy and more recoverable. Add a disaster recovery strategy to your business by simply rotating cartridges off site. off-site.Complement your cloud storage and implement best practices with a local backup copy that allows you faster access to critical data whenever you need it. Protecting your information both on- and off-premises.Delivering hard drive data transfer speeds and built in anti-vibration buffers, to increase read/write speeds, lowering the time it takes for incremental or full backups. This leaves you free to concentrate on running your business.As backup needs grow, you can easily and affordably expand your system by simply adding more cartridges - no new is hardware required. The HPE RDX Removable Disk Backup System supports disk spanning so data can bridge multiple cartridges.Compatibility across various operating systems and virtualization platforms makes it simple to adapt into any small business environment. You can also use Fixed Disk mode for automated backups via the native Microsoft Windows operating system.
  • Unmatched Portability
    Low-power ruggedized design offers flexibility to plug it in anywhere and feel confident the data is always available and safe.Cartridge style hard drive has a 97 percent survival rate compared to 0 percent for ordinary USB drives in a independent drop test.Built in static protection eliminates server or workstation failures due to statically charged peripherals.
  • Fast Backup and Recovery
    Ability to recover quickly with disk to disk backup performance reaching speeds of up to 360 GB/hr.Supports drag and drop file access making backup as simple and convenient as the click of the mouse.No need to worry about backups being larger than disk space, with disk spanning just add cartridges during the backup process, dynamically increasing the backup.Inner buffers built into the system lower disk drive vibration, increasing read/write disk performance.
  • Easy Integration
    HPE qualified and tested, making it easy to integrate into your server storage and networking environments.With fixed disk mode capability, RDX easily integrates into multiple small business operating system environments.Internal dock option makes it easy to configure with ProLiant and StoreEver products.
HPE RDX Removable Disk Backup System - RDX drive - USB 2.0 - external - with 500 GB Cartridge
RDX drive - external
USB 2.0
10.98 cm x 17.75 cm x 5.18 cm
540 g
Storage Removable
RDX cartridge
Media Type
RDX cartridge
Data Transfer Rate
30 MBps (external) / 480 MBps (internal)
(50/60 Hz)
Microsoft Certification
Compatible with Windows 7
Bundled with
500 GB Cartridge
Workstation xw4600; ProLiant DL120 G6, DL165 G7, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G5, DL385 G7, DL580 G7, DL585 G5, DL585 G7, DL785 G6, ML110 G6, ML330 G6, ML350 G6, ML370 G6; StorageWorks Network Storage System X1400, X1400 8TB, X1600, X1600 24, X1600 292, X1600 3TB, X1600 7.5TB, X1800
USB 2.0
10.98 cm
17.75 cm
5.18 cm
540 g
Bundled with
500 GB Cartridge
Storage Removable
RDX cartridge
Media Type
RDX cartridge
Data Transfer Rate
Average Seek / Access Time
15 ms
1 x USB 2.0 - 4 pin USB Type B
Media Included Qty
1
1 x USB cable
MTBF
550,000 hours
VCCI, C-Tick, EN 60950, IEC 60950, UL 60950, CISPR 22, FCC
(50/60 Hz)
6.6 Watt
Software Included
Drivers & Utilities, HP RDX Continuous Data Protection Software
5 °C
45 °C
20 - 80% (non-condensing)
HP Workstation xw4600 , HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL160 G5p Special Server, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Special Server, DL180 G6 Special Server, DL320 G4 SAS VPN Server, DL320 G4 SATA VPN Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Package Cluster, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G5 Carrier-Grade, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5 Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server, ML150 G5 Special Server, ML150 G6 Base, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server , HPE StorageWorks Network Storage Gateway X3400 , HPE StorageWorks Network Storage System X1400, X1400 2TB SATA Model, X1400 4TB SATA Model, X1400 8TB SATA Model, X1600, X1600 12TB SATA Model, X1600 24TB SATA Model, X1600 292GB SAS Model, X1600 3TB SAS Model, X1600 5.4TB SAS Model, X1600 6TB SATA Model, X1600 7.5TB SAS Model, X1800, X1800 2.4TB SAS Model, X1800 292GB SAS Model, X1800 3.6TB SAS Model, X1800 6TB SATA Model
