Take notes, navigate, draw, doodle, and edit onscreen with the resilient, multifunction, long-life HP Pro Pen.
Clickable functions for easy onscreen interaction
Use the active pen to select items and navigate and erase content with right-click, left-click, and double-click functions. Work without worry about wear and tear - the pen's cone tip is designed for minimal breakage. -
A natural, comfortable writing experience
Hold and write comfortably with an easy-grip texture and familiar length. -
Close at hand when you need it
Keep track of the pen with a slant design that doesn't roll off the desk. Pair with the tether to ensure your pen is where you need it, when you need it.
- HP Pro Pen - digital pen - black
- Digital pen
- Black
- 14 cm
- 10.7 g
- Buttons Qty
- 2
- Pressure sensitive pen, Palm Rejection Technology, 4096 pressure levels
- Battery
- AAAA type
- OS Required
- Windows 10
- Digital pen
- 14 cm
- 10.7 g
- Black
Input Device
- Buttons Qty
- 2
- Included Accessories
- Additional pen tip, AAAA battery, tip replacement tool
- AAAA type
- Run Time (Up To)
- 1 year
- OS Required
- Windows 10
