Get creative and print lab-quality photos via the large touchscreen and auto-engaging photo paper tray. Print and share however you choose, wirelessly or with HP ePrint mobile printing – now you can print from virtually anywhere..
Print brilliant, lab-quality photos without a PC via the large touchscreen
Print lab-quality photos – scan and copy too – directly from the large and intuitive touchscreen.Switch between everyday and photo paper or other media using the auto-engaging photo paper tray.Connect to online photo libraries without a PC or print direct from memory card.Enjoy affordable printing with individual inks; optional XL cartridges for frequent printing. -
Create impressive everyday projects via web-based apps, two-sided printing and more
Save time and paper with reliable, automatic two-sided printing – great for creative projects.Access easy-to-use apps and print Sudoku puzzles, colouring pages and more – all without a PC.Choose HP Quick Forms and print templates such as calendars, games and notebook pages.Do it all from the large, easy-to-use colour touchscreen – print, copy, scan and create, even access web content.
- HP Photosmart 6510 e-All-in-One B211a - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 impressions
- Max Copying Speed
- Up to 6.5 ppm (mono) / up to 5.5 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 11 ppm (mono) / up to 7.5 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, photo paper
- Standard Media Capacity
- 80 sheets
- Output Trays Capacity
- 20 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- Office Machine Features
- Print from memory card
- Power
- AC 110/230 V (50/60Hz)
- 43.6 cm x 38.1 cm x 16.1 cm
- 5.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Ink-jet - colour - photo
- 1000 impressions
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 64 MB 64 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 50
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Legal
- Min Media Weight
- 75 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, C6 (114 x 162 mm), 76 x 127 mm, 100 x 300 mm, 110 x 220 mm
- 80 sheets
- 20 sheets
- Input tray - 80 sheets , Output tray - 20 sheets - 300 g/m² , Input tray - 20 sheets - 130 x 180 mm - 280 g/m²
- Speed Details
- Printing: up to 11 ppm - B/W best , Printing: up to 7.5 ppm - colour best , Copying: up to 6.5 ppm - B/W best , Copying: up to 5.5 ppm - colour best
- 1 x USB 2.0
- Operating System Support
- MS Windows XP SP2 or later, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7
- Software Included
- HP Photo Creations
- Voltage Required
- 13 Watt
- Power Consumption Standby
- 5.1 Watt
- Power Consumption Sleep
- 2.7 Watt
- Consumables Included
- 1 x ink cartridge (black) - HP 364 , 1 x ink cartridge (cyan) - HP 364 , 1 x ink cartridge (magenta) - HP 364 , 1 x ink cartridge (yellow) - HP 364
- ENERGY STAR Certified
- 43.6 cm
- 38.1 cm
- 16.1 cm
- 5.6 kg
- Shipping Weight
- 7.1 kg
- Sound Emission
- 50 dBA (operating)
- 5 °C
- 40 °C
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.41 |
