Stay productive and tackle high-volume jobs with print, fax, scan, and copy versatility. Save up to 70% on ink with HP Instant Ink.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
Colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen. -
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup. -
Print, scan, copy, and fax with ADF
Save time by sending scanned documents or photos directly from your printer to email recipients.
- HP Officejet Pro 8710 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 20 ppm (mono) / up to 14 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, fax to e-mail
- Power
- AC 120/230 V (50/60Hz)
- 49.95 cm x 53.01 cm x 33.91 cm
- 11.54 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 3, PCL 3e, PDF, PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 180 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm), 215.9 x 279.4 mm
- 250 sheets
- 250 sheets
- 150 sheets
- ADF - 50 sheets , Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 180 g/m² , Output tray - 150 sheets
- Speed Details
- Scanning: up to 17 ipm - B/W , Scanning: up to 8 ipm - colour , Scanning: up to 17 ipm - B/W duplex , Scanning: up to 8 ipm - colour duplex , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 18 ppm - colour (ISO) , Printing: up to 35 ppm (Letter A) - B/W draft , Printing: up to 35 ppm (Letter A) - colour draft , Copying: up to 30 ppm (Letter A) - B/W draft , Copying: up to 27 ppm (Letter A) - colour draft , Copying: up to 20 ppm - B/W (ISO) , Copying: up to 14 ppm - colour (ISO) , Copying: up to 30 ppm (A4) - B/W draft , Copying: up to 27 ppm (A4) - colour draft , Printing: up to 35 ppm (A4) - B/W draft , Printing: up to 35 ppm (A4) - colour draft
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities, I.R.I.S. OCR, HP Participation Study
- Voltage Required
- 35 Watt
- Power Consumption Standby
- 6.1 Watt
- Power Consumption Sleep
- 1.2 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 800 pages - HP 953 , 1 x ink cartridge (cyan) - up to 490 pages - HP 953 , 1 x ink cartridge (magenta) - up to 490 pages - HP 953 , 1 x ink cartridge (yellow) - up to 490 pages - HP 953
- ENERGY STAR Certified
- 49.95 cm
- 53.01 cm
- 33.91 cm
- 11.54 kg
- Shipping Weight
- 14.5 kg
- Sound Emission
- 63 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
