HP Office Inkjet All-in-One Printers deliver professional colour and black-and-white documents at a low cost per page, plus a full range of copy and scan tools with advanced paper-handling options.
Print professional documents at up to 50% less cost-per-page than lasers. Equipped with HP ePrint, you can create your own customized email address and print from virtually anywhere with any email-capable device. Also use business apps to access content directly from the web without a PC. It has a low cost-per-page with available high-capacity ink cartridges that offer a better value for frequent printing. It also features a 50-sheet automatic document feeder with 2-sided copy, scan, fax and direct digital filing features such as scan to email, scan to network folder and scan to the web.
Professional color for a lower cost than lasers.
- Print professional color for up to 50% lower cost per page than lasers, and get a better value for frequent printing.[4]
- Print documents that resist fading, water and highlighter-pen smears, using HP Officejet inks.[2][3]
- Achieve ISO print speeds up to 20 ppm black and 16 ppm color,[5] using affordable, individual inks.
- Depend on a printer with a 25,000-page monthly duty cycle--the perfect fit for reliable color printing.
Efficient Web connectivity--even print on the go.[6]
- Print from a variety of mobile devices on the go. With HP ePrint--now you can print from virtually anywhere.[6]
- Use the large touchscreen with gesturing to access business apps, plus quickly print and store files.
- Easily view and print photos from a USB drive and memory cards.
- Stay connected--share on a wireless or wired network.[7]
Standout versatility with copy and scan solutions.
- Create flawless copies with CopySmart solutions, and easily print two-sided identification cards.
- Do more with automatic two-sided print, copy and scan capabilities and the 50-page automatic document feeder.
- Improve workflow--send quick faxes, scan up to legal-size documents to a PC or e-mail, and more.
- Create borderless, double-sided flyers and brochures, plus print impressive business photos.
Exceptional energy and resource savings.
- Use up to 50% less energy than lasers with this ENERGY STAR® qualified printer, and preset On or Off times.
- Easily recycle cartridges, and use up to 70% less supplies and packaging by weight compared with lasers.
- Consume up to 50% less paper while printing, using automatic two-sided printing.
- Use Original HP ink cartridges for quality, reliability and rewards.
[2]Based on paper-industry predictions for acid-free papers and Original HP inks; colorant stability data at room temperature based on similar systems tested per ISO 11798 and ISO 18909.
[3]Based on HP internal testing, using paper with the ColorLok® logo.
[4]Compared with the HP Officejet 950/951 Black and color ink cartridges. For more information, see http://www.hp.com/go/learnaboutsupplies. High-capacity cartridges not included; please purchase separately.
[5]After first set of ISO test pages. For more information, see http://www.hp.com/go/printerclaims.
[6]Requires an Internet connection to the printer. Feature works with any connected Internet- and e-mail-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see http://www.hp.com/go/eprintcenter. And for additional solutions see http://www.hp.com/go/mobile-printing-solutions.
[7]Wireless performance is dependent upon physical environment and distance from access point. Wireless operations compatible with 2.4 GHz routers only.
ENERGY STAR® qualified models; see http://www.hp.com/go/energystar
[1] Either after first page or after first set of ISO test pages. For details see http://www.hp.com/go/printerclaims
[2] Power measurements are based on ENERGY STAR® OM test procedure with 230 VAC, 50 Hz input.
[3] Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. Some ink from included cartridge is used to start up the printer. For details see http://www.hp.com/go/learnaboutsupplies
Get more done with a range of efficiency-enhancing business tools
Boost productivity with automatic two-sided printing, scanning and copying with 50-page automatic document feeder.Send digital faxes direct from your desktop and scan documents directly to a PC, email or network folder.Create double-sided flyers, borderless photos, impressive leaflets and other professional-looking materials.Create flawless copies with CopySmart solutions; easily create and print a one-sided copy of a two-sided ID card.
- HP Officejet Pro 8600 Plus e-All-in-One N911g - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 impressions
- Recommended Monthly Volume
- 250 - 1250 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 20 ppm (mono) / up to 16 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Scanning
- 4800 x 4800 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from memory card, scan to e-mail
- Power
- AC 110/230 V (50/60Hz)
- 49.4 cm x 41.3 cm x 31.5 cm
- 12.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour - photo
- 25000 impressions
- 250 - 1250 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB 128 MB
- Max Supported Memory
- 128 MB 128 MB
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, miniSD, Memory Stick PRO, Memory Stick Duo, SDHC Memory Card, RS-MMC, MultiMediaCardmobile
Copying
- Max Copying Speed
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 13 sec
- First Print Out Time Colour
- 14 sec
Scanning
- Optical Resolution
- 4800 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Delayed Transmission
- Fax forwarding, automatic redialing, answering machine interface, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax memory backup, delayed sending, fax polling, block fax, save and load speed dials, poll receive, fax activity reports, print fax log
Document & Media Handling
- Max Original Size
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 148 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- 250 sheets
- 500 sheets
- 150 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 35 ppm (A4) - B/W draft , Printing: up to 35 ppm (A4) - colour draft , Printing: up to 20 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Printing: up to 5 ppm (A4) - B/W best , Printing: up to 3 ppm (A4) - colour best , Copying: up to 35 ppm (A4) - B/W draft , Copying: up to 35 ppm (A4) - colour draft , Copying: up to 13 ppm (A4) - B/W normal , Copying: up to 12 ppm (A4) - colour normal , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 1.5 ppm (A4) - colour best
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- Linux, Apple Mac OS X 10.5, MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7
- Software Included
- Drivers & Utilities
- Voltage Required
- 34 Watt
- Power Consumption Standby
- 6.6 Watt
- Power Consumption Sleep
- 2.2 Watt
- Consumables Included
- 1 x ink cartridge (black) - up to 1000 pages - HP 950 , 1 x ink cartridge (cyan) - up to 700 pages - HP 951 , 1 x ink cartridge (magenta) - up to 700 pages - HP 951 , 1 x ink cartridge (yellow) - up to 700 pages - HP 951
- ENERGY STAR Certified
- 49.4 cm
- 41.3 cm
- 31.5 cm
- 12.6 kg
- Sound Emission
- 60 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.77 |
HP 950XL High Yield Black Original Ink Cartridge | In Stock | £41.48 |
HP 951XL High Yield Cyan Original Ink Cartridge | In Stock | £30.37 |
HP 951XL High Yield Magenta Original Ink Cartridge | In Stock | £30.37 |
HP 951XL High Yield Yellow Original Ink Cartridge | In Stock | £30.37 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.78 |
