Create premium-quality colour documents and save as much as 50% per page compared with competitive laser printers1 with this high-speed, network-ready printer. Share the performance - including two-sided printing - between as many as 5 users.
The HP Officejet Pro 8000 Printer is designed for micro/small business users wanting an energy-efficient, network-ready printer capable of delivering premium-quality colour and black-and-white at an exceptionally low cost per page. Print professional colour documents for a cost per page up to 50% lower than lasers. Get professional print quality for high impact general office documents, with a cost per page as much as 50% lower than competitive lasers. Save on external print costs too - produce customised marketing materials as and when you need them.
Handle documents straight from the printer with new generation HP Officejet pigment inks - specially formulated to deliver durable, water-resistant outputs3. Individual cartridges mean you need only replace those that run out. Use as much as 50% less energy than lasers and save paper too.
Minimise your impact on the environment with this efficient, ENERGY STAR® qualified device - use up to 50% less energy than with competitive colour laser printers2. Reduce paper use by as much as half too, by printing both sides using automatic two-sided printing. Get more usable web pages with HP Smart Web Printing4 - combine multiple web pages into a single printed page with no cut-off edges. Manage your printers over the network with device management software.
Streamline user productivity - share fast print performance over your Ethernet network.
Boost individual and small workteam productivity - share high-speed performance between up to 5 users via embedded Ethernet networking. Get professional results fast - enjoy speeds equivalent to a laser printer with up to 15 black / 11 ppm colour5, plus draft/fastest speeds of up to 35 ppm black / 34 ppm colour
Streamline user productivity – share fast print performance over your Ethernet network
Share high-speed performance between up to 5 users via your Ethernet network. Enjoy speeds equivalent to a laser printer with up to 15 black / 11 ppm colour, plus draft/fastest speeds of up to 35 ppm black / 34 ppm colour.
- HP Officejet Pro 8000 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 7.8 kg
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink
- Media Size Class
- Legal
- Max Media Size
- Legal (216 x 356 mm)
- Print Speed
- Up to 35 ppm - black draft - A4 (210 x 297 mm) , Up to 34 ppm - mixed text/colour graphics draft - A4 (210 x 297 mm) , Up to 19 ppm - black normal - A4 (210 x 297 mm) , Up to 19 ppm - mixed text/colour graphics normal - A4 (210 x 297 mm) , Up to 5 ppm - black best - A4 (210 x 297 mm) , Up to 3.5 ppm - mixed text/colour graphics best - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 384 MHz
- RAM Installed (Max)
- 32 MB (32 MB)
- Language Simulation
- PCL 3, PCL 3E
- Media Type
- Envelopes, transparencies, labels, plain paper, photo paper, index cards
- Total Media Capacity
- 250 sheets
- Monthly Duty Cycle (max)
- 15000 pages
- Networking
- Print server - Ethernet
- Printer Features
- Borderless printing
- System Requirements
- Microsoft Windows XP Professional SP1, Microsoft Windows XP Home Edition SP1, Microsoft Windows 2000 SP4, Microsoft Windows Vista, Apple MacOS X 10.5, Apple MacOS X 10.4.11, Microsoft Windows XP Professional x64 Edition SP1
- Microsoft Certification
- Certified for Windows Vista
- 3-year warranty with product registration
- 49.4 cm x 47.9 cm x 18 cm
- Printer Type
Printer
- Inkjet Technology
- HP Thermal Inkjet
- 4-ink
- Ink Type
- HP Vivera Inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 dpi
- 4800 x 1200 dpi
- PCL 3, PCL 3E
- Printer Features
- Processor
- 384 MHz
RAM
- 32 MB / 32 MB (max)
Media Handling
- Media Type
- Media Size Class
- Legal
- Max Media Size
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- Max Printing Width
- 216 mm
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 15000 pages
- Networking
- Print server
- Data Link Protocol
- Ethernet
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - HP 940 , 1 x ink cartridge (cyan) - HP 940 , 1 x ink cartridge (magenta) - HP 940 , 1 x ink cartridge (yellow) - HP 940
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- 48 Watt
- Power Consumption Stand by / Sleep
- 3.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years with product registration
- 15 °C
- 35 °C
- 10 - 80%
- 49.4 cm
- 47.9 cm
- 18 cm
- 7.8 kg
- Width (Shipping)
- 59.1 cm
- Depth (Shipping)
- 52.3 cm
- Height (Shipping)
- 32.8 cm
- Weight (Shipping)
- 11.8 kg
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.08 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.71 |
