Print professional colour documents for business for up to 50% lower cost per page than lasers. This e-all-in-one is designed for productivity with smart features and mobile printing to keep business moving – at work, home or on the go.
Print on your terms
Print wirelessly from your mobile device – no router or access to local network required.Print documents, photos and more when you're on the go – from virtually anywhere – using HP ePrint.Easily connect to your local network and the Internet, wirelessly or using the 10/100 Ethernet port.Manage this HP e-all-in-one and scan on the go with the free HP All-in-One Printer Remote mobile app. -
Conserve resources without sacrificing performance
Use up to 50% less energy compared with the majority of colour laser AiOs.Save energy on your schedule – preset your device to turn on when you need it and off when you don't.Conserve resources – use up to 80% less supplies and packaging by weight compared with the majority of colour laser AiOs.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet Pro 6830 e-All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Max Copying Speed
- Up to 10 ppm (mono) / up to 7 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 18 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 dpi
- Display
- 2.65"
- Original Size
- 212 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, glossy paper, matte paper
- Standard Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Power
- AC 110/230 V (50/60Hz)
- 46.185 cm x 38.765 cm x 22.4 cm
- 8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 15000 pages
- 200 - 800 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1 GB
- Max Supported Memory
- 1 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 17 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Yes (black only)
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier
Document & Media Handling
- Max Original Size
- 212 x 356 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 88.9 x 127 mm, 101.6 x 127 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 215 x 355 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- 216 x 297 mm
- 225 sheets
- 60 sheets
- Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 35 sheets - 212 x 356 mm , Output tray - 60 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 10 ppm (A4) - colour (ISO) , Copying: up to 10 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Scanning: up to 5 ppm - B/W , Scanning: up to 2.8 ppm - colour , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - colour draft , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 24 ppm (A4) - colour draft
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x modem - RJ-11
- Operating System Support
- Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit
- Software Included
- Drivers & Utilities
- Voltage Required
- 25 Watt
- Power Consumption Standby
- 4.9 Watt
- Power Consumption Sleep
- 1.35 Watt
- Included Accessories
- Ethernet cable
- EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EMC
- ENERGY STAR Certified
- 46.185 cm
- 38.765 cm
- 22.4 cm
- 8 kg
- Shipping Width
- 50.8 cm
- Shipping Depth
- 28.2 cm
- Shipping Height
- 46.4 cm
- Shipping Weight
- 10 kg
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
