NVIDIA Quadro M2000 - Graphics card - Quadro M2000 - 4 GB GD
Quicklinx: CKMJWS00 Mfr#: T7T60AT
Get fast performance and work interactively with models and scenes across CAD, DCC, and medical applications with the new Maxwell GPU architecture features of the flexible, single-slot NVIDIA Quadro M2000 graphics card.
Experience ultra-fast visualization and compute horsepower with 4GB ultra-fast GDDR5 memory and CUDA® parallel processing.
Drive up to four 4K or two 5k displays or one 8K projector with four DisplayPort 1.2 ports and managed them with included NVIDIA® Mosaic™ and NVIDIA® nView® technologies. Enable immersive collaboration with optional 3D Vision™ and 3D Vision Pro.
Boost application performance in real time while staying within the power and thermal envelope of the card with NVIDIA® GPU Boost.
Easily support your professional software application base with comprehensive ISV certifications.
Compatible with Z240 CMT, Z440, Z640, Z840.
  • High-speed compute power
    Experience ultra-fast visualization and compute horsepower with 4GB ultra-fast GDDR5 memory and CUDA parallel processing.
  • One card, many display possibilities
    Drive up to four 4K or two 5k displays or one 8K projector with four DisplayPort 1.2 ports and managed them with included NVIDIA Mosaic and NVIDIA nView technologies. Enable immersive collaboration with optional 3D Vision and 3D Vision Pro.
  • Integrated NVIDIA GPU Boost
    Boost application performance in real time while staying within the power and thermal envelope of the card with NVIDIA GPU Boost.
  • Certified for your most common ISVs
NVIDIA Quadro M2000 - graphics card - Quadro M2000 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M2000
4 GB GDDR5
CUDA Cores
768
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 at 60 Hz / DisplayPort: 2560 x 1600 at 120 Hz
Max Monitors Supported
4
Interfaces Details
4 x DisplayPort (HDCP)
API Supported
OpenCL, DirectCompute 5.0, DirectX 12, OpenGL 4.5
16.7 cm x 11 cm
Pricing Type
Promo
Workstation Z240 (MT, tower), Z440, Z640, Z840
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M2000
CUDA Cores
768
Max Resolution
4
Interfaces Details
API Supported
Nvidia CUDA technology, NVIDIA Mosaic, NVIDIA GPU Boost, Multi-Stream Technology, Maxwell architecture, HDCP
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
105.7 GBps
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
75 Watt
16.7 cm
11 cm
230 g
Pricing Type
Promo
HP Workstation Z240 (MT, tower), Z440, Z640, Z840
