HPE HP NVIDIA QUADRO K2000 2GB Graphics Card
Quicklinx: 933VWS00 Mfr#: C2J93AT
The NVIDIA Quadro K2000 graphics board is a single-slot PCI Express add-in card based on the new NVIDIA Kepler architecture graphics processing unit (GPU). The Quadro K2000 graphics board is an excellent choice for medium complexity designs and models in professional CAD, M&E and visualization applications.
  • Greater model complexity in the design workflow
    Streaming multiprocessor (SM) design, called SMX, offers several important architectural changes. You can realize substantial increases in per-clock throughput of key graphics operations that combine to deliver unprecedented performance and power efficiency. Plus, the Quadro solutions offer large frame buffer capacity, letting you work with larger models and assemblies and improving interactive manipulation performance during the design process.
  • Ultra-high resolution visualization
    You can now drive up to four displays simultaneously and get full support for the next-generation DisplayPort standard - capable of resolutions of 3840 x 2160 at 60 Hz. This makes it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment. NVIDIA's latest technologies give you an easy, affordable way to perform image synchronization and resolution scaling of a synchronized display surface with multiple projectors or displays.
  • Richer scene details and effects
    The NVIDIA Kepler architecture introduces the concept of bindless textures, which enables the GPU to reference textures directly in memory. This effectively eliminates the limit on the number of unique textures that can be used to render a scene, and reduces the CPU overhead to deliver improved performance. In fact, over one million unique textures are now possible. Fast approximate anti-aliasing (FXAA) and temporal anti-aliasing (TXAA) film-style technologies give you outstanding image quality for content creation and design reviews without compromising the interactive experience.
  • NVIDIA CUDA architecture
    Parallel-computing architecture that tightly integrates advanced visualization and compute features to significantly accelerate professional workflows.
  • NVIDIA scalable geometry engine
    Dramatically improves geometry performance across a broad range of CAD, DCC, and medical applications. This gives you the freedom to work interactively with models and scenes that are an order of magnitude more complex than ever before.
  • NVIDIA Parallel DataCache
    Supports a true cache hierarchy combined with on-chip shared memory. L1 and L2 caches drive exceptional throughput, accelerating features such as real-time ray tracing, physics, and texture filtering.
  • Bindless textures
    Dramatically increases the number of unique textures available to shaders at run-time, enabling significantly more materials and richer texture detail in scenes.
  • H.264 encoder
    Dedicated H.264 encode engine that's independent of 3D/compute pipeline and delivers real-time performance for transcoding, video editing, and other encoding applications.
  • Ultra-quiet design
    An advanced cooling design enables acoustics lower than 28 db for an ultra-quiet desktop environment.
  • NVIDIA FXAA and TXAA
    Reduces visible aliasing and delivers higher image quality - without the performance hit - by harnessing the power of the GPU's CUDA cores and film-style antialiasing techniques.
  • GPU Tessellation with Shader Model 5.0
    Quadro tessellation engines automatically generate finely detailed geometry for cinematic quality environments and scenes, without sacrificing performance.
  • 16K texture and render processing
    Provides the ability to texture from and render to 16K x 16K surfaces. This is beneficial for applications that demand the highest resolution and quality image processing.
  • NVIDIA Quadro Mosaic technology
    Enables transparent scaling of the desktop and applications across up to 16 displays from four GPUs through a single workstation while delivering full performance and image quality.
  • Multi-Display support
    The display engine in the NVIDIA Kepler GPU drives up to four displays simultaneously, whether they're directly connected to the board or connected using a single cable using DisplayPort multi-streaming capabilities. With support for the next-generation DisplayPort standard, each DisplayPort connector is also capable of driving ultra-high resolutions like 3840 x 2160 at 60 Hz with 30-bit color. The flexible display connectivity of the Quadro family makes it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment.
  • Deep color processing and display
    Preserve color detail and precision throughout the processing and display pipeline for smooth gradients transitions, even on high dynamic range imagery. Each color component can be processed at up to 32-bit floating point precision and displayed at up to 12-bit precision with supported DisplayPort or HDMI displays.
  • NVIDIA 3D Vision and 3D Vision Pro
    Advanced active-shutter glasses that deliver crystal-clear stereoscopic 3D visualization for the most immersive experience. Infrared (3D Vision) or RF (3D Vision Pro) technologies allow a range of immersive environments from your desktop workstation to collaborative work spaces. 3D Vision and 3D Vision Pro are sold separately.
  • Professional 3D stereo synchronization
    Enables robust control of the stereo effect through a dedicated three-pin, mini-din connection to directly synchronize 3D stereo hardware to the Quadro graphics card.
  • NVIDIA CUDA parallel computing architecture
    Quadro solutions leverage general-purpose GPU computing using standard programming languages like C/C++ and Fortran, as well as emerging APIs such as OpenCL and Direct Compute. This broad adoption of CUDA accelerates techniques like ray tracing, video and image processing, and computation fluid dynamics.
  • NVIDIA GPUDirect for video
    Allows third-party hardware to communicate directly with NVIDIA GPUs. Taking advantage of this API addresses the historical issues of introducing too much delay or latency because devices are fully synchronized and the CPU doesn't waste cycles copying data between device drivers. NVIDIA Enterprise-management tools exhaustive tools for maximizing your system uptime by enabling seamless wide-scale deployment. This allows remote query and control of graphics and display settings for systems spread across installations.
  • Support for multiple operating systems on a single machine
    With a dedicated GPU per user and virtualization software, users can experience the full GPU acceleration of a standard workstation while improving resource management and utilization.
NVIDIA Quadro K2000 - graphics card - Quadro K2000 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2000
2 GB GDDR5
Effective Memory Clock
2 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 2560 x 1600
Max Monitors Supported
4
2 x DisplayPort , DVI-I (dual link)
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.3
20.24 cm x 11.12 cm
Workstation Z220 (CMT), Z420, Z620, Z820
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K2000
RAMDAC
400 MHz
Max Resolution
2560 x 1600 at 60 Hz
4
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Shader Model 5.0, Kepler GPU Architecture, Nvidia Quadro Mosaic Technology
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
2 GHz
Bus Width
128-bit
Bandwidth
64 GBps
Red Hat Enterprise Linux Desktop 5, SUSE Linux Enterprise Desktop 11, Microsoft Windows 7 Professional (32/64 bits), Red Hat Enterprise Linux Desktop 6, Windows 8 Pro 64-bit Edition
51.1 Watt
1 x DisplayPort-DVI adapter
20.24 cm
11.12 cm
HP Workstation Z220 (CMT), Z420, Z620, Z820
