HP NVIDIA Quadro K1200 - Graphics card - Quadro K1200 - 4 GB GD
Quicklinx: CKMHWS00 Mfr#: T7T59AT
Deliver outstanding professional 3D application performance for product development challenges and media and entertainment creation with the NVIDIA Quadro K1200 low profile plug-in graphics card designed for small form factor HP Z Workstations.
Easily support your professional software application base with comprehensive ISV certifications. Enjoy fast performance from 4 GB of GDDR5 GPU memory that supports large models and data sets.
Drive ultra-high display resolutions like 4096 x 2160 @ 60 Hz with 30-bit color using the integrated display engine and four miniDP connectors. Easily manage up to four displays with NVIDIA® Mosaic and NVIDIA® nView® technologies.
Accelerate single-precision computing workflows with 512 NVIDIA® CUDA® parallel processing cores in a single-slot, low-profile card.
Compatible with the Z240 Worksation Serie.
  • ISV certifications and solid performance
  • Flexible and easy display management
    Drive ultra-high display resolutions like 4096 x 2160 @ 60 Hz with 30-bit color using the integrated display engine and four miniDP connectors. Easily manage up to four displays with NVIDIA Mosaic and NVIDIA nView technologies.
  • Precise performance
    Accelerate single-precision computing workflows with 512 NVIDIA CUDA parallel processing cores in a single-slot, low-profile card.
NVIDIA Quadro K1200 - graphics card - Quadro K1200 - 4 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K1200
4 GB GDDR5
CUDA Cores
512
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Dual-Link): 2560 x 1600 at 60 Hz/ DVI (Single-Link): 1920 x 1200 at 60 Hz/ DisplayPort: 4096 x 2160 at 60 Hz/ VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
Interfaces Details
4 x Mini DisplayPort
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.1, OpenGL 4.4
17.5 cm x 6.88 cm
Pricing Type
Promo
1-year warranty
Workstation Z230, Z240, Z440, Z640, Z840
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K1200
CUDA Cores
512
Max Resolution
4
Interfaces Details
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Shader Model 5.0, Multi-Stream Transport, Nvidia Quadro Mosaic Technology, High Bit Rate 2, Maxwell architecture
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
80 GBps
Linux, Microsoft Windows 7 / 8 / 8.1
46 Watt
17.5 cm
6.88 cm
175 g
Pricing Type
Promo
Limited warranty - 1 year
HP Workstation Z230, Z240, Z440, Z640, Z840
