Improve your graphics experience - Experience PCI Express x 16 graphics technology in a low profile card for your small form factor PC.
The NVIDIA NVS 310 graphics board offers 1GB of ultrafast DDR3 memory and is capable of supporting up to 2 displays.
Reduce the need to share your PC system memory with 1GB of DDR3, dedicated on-board graphics memory. (Graphics cards use part of the total system memory (RAM) for graphics performance. System memory dedicated to graphics performance is not available for other use by other programs.)
Run dual displays with the integrated DisplayPort 1.2 connector for more screen real-estate in graphic-intensive applications.
Enable DX11 applications and OpenGL applications for optimal performance with hardware-ready DirectX11 and OpenGL4.2 support.
- NVIDIA NVS 310 - graphics card - Quadro NVS 310 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA Quadro NVS 310
- Memory
- 1 GB DDR3
- Effective Memory Clock
- 875 MHz
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 2
- 2 x DisplayPort
- API Supported
- DirectX 11, OpenGL 4.1
- 15.6 cm x 6.89 cm
- 1-year warranty
- Designed For
- HP 4000 Pro, 6005 Pro, 6200 Pro, 6300 Pro, 8200 Elite, Elite 8300, Pro 4300; EliteDesk 705 G3, 705 G4, 800 G2 (SFF, tower); ProDesk 400 G3 (micro tower), 400 G4, 490 G3, 600 G2 (micro tower, SFF); Workstation Z440, Z640, Z840
- Bus Type
- Graphics Engine
- Max Resolution
- 2560 x 1600 at 60 Hz
- 2
- 2 x DisplayPort
- API Supported
- NVIDIA Mosaic, Shader Model 5.0
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 875 MHz
- Bandwidth
- 14 GBps
- OS Required
- Red Hat Enterprise Linux, Microsoft Windows 7 Professional (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit), Windows 8 / 8.1
- 19.5 Watt
- 15.6 cm
- 6.89 cm
- 142 g
- Limited warranty - 1 year
- Designed For
- HP EliteDesk 705 G3, 705 G4, 800 G2 (SFF, tower) , HP ProDesk 400 G3 (micro tower), 400 G4, 490 G3, 600 G2 (micro tower, SFF) , HP Workstation Z440, Z640, Z840 , HP Compaq 4000 Pro, 6005 Pro, 6200 Pro, 6300 Pro, 8200 Elite, Elite 8300, Pro 4300
