The HP NC373F is a high performance PCI Express multifunction network adapter that supports standard or low profile slots in ProLiant servers running over a fiber-optic network environment. The NC373F is a four lane (x4) serial device with 92KB of onboard memory. In addition to delivering Gigabit Ethernet networking, the NC373F supports TOE (TCP/IP Offload Engine), iSCSI (Internet Small Computer System Interface), and RDMA (Remote Direct Memory Access) over a single network connection.
The NC373F ships with all the advanced server features that ProLiant customers have come to expect, such as support for failover and load balancing, Pre-Boot Execution Environment (PXE), jumbo frames, large send offload, and multiple VLAN tagging.
- HP NC373F PCI Express Multifunction Gigabit Server Adapter - network adapter
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x4
- PCI Specification Revision
- PCIe 1.0a
- 16.8 cm x 6.4 cm
- Cabling Type
- Ethernet 1000Base-SX
- Data Link Protocol
- Gigabit Ethernet
- Data Transfer Rate
- 1 Gbps
- RAM
- 92 KB
- IEEE 802.3z, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3p
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Standard Edition, Red Hat Enterprise Linux 3, Microsoft Windows Server 2003 Standard x64 Edition, Red Hat Enterprise Linux 4, Microsoft Windows Server 2003 Enterprise x64 Edition, SuSE Linux Enterprise Server 9 for x86/AMD64
- Designed For
- ProLiant DL120 G6, DL120 G7, DL160se G6, DL165 G7, DL170h G6, DL320 G6, DL360 G7, DL370 G6, DL380 G7, DL385 G7, DL580 G5, DL580 G7, DL585 G6, DL585 G7, DL785 G6, ML370 G6, SL160s G6, SL160z G6, SL165s G7, SL165z G7, SL170z G6; StorageWorks X1400 G2, X1500 G2, X1600 G2, X1800 G2, X3800 G2
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x4
- PCIe 1.0a
- 16.8 cm
- 6.4 cm
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet
- 1 Gbps
- Status Indicators
- Link activity
- Load balancing, Accelerated iSCSI, TCP/IP offloading
Processor / Memory
- RAM
- 92 KB
- 1 x network - Ethernet 1000Base-SX - LC x 2
- Compatible Slots
- 1 x PCI Express x4
- Included Accessories
- Low-profile bracket
- FCC Class B certified, VCCI, EN 60950, EN55022, ICES-003, RRL, IEC 60950, EN55024, UL 60950, CSA 22.2 No. 60950, MIC, AS/NZS 3548, FCC CFR47 Part 15
- OS Required
- 0 °C
- 55 °C
- 10 - 90%
- Designed For
- HP ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160se G6, DL165 G5, DL165 G6, DL165 G7, DL165 G7 Performance, DL170h G6, DL180 G5, DL180 G6, DL185 G5, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL365 G5 Base, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL385 G5, DL385 G5 Entry, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G5 Highly Serviceable Tower, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL165s G7, SL165z G7, SL170z G6, SL2x170z G6 , HP StorageWorks All-in-One Storage System 1200r 12TB SATA Model, 1200r 2.4TB SAS Model, 1200r 3.6TB SAS Model, 1200r 3TB SATA Model, 1200r 5.4TB SAS Model, 1200r 6TB SATA Model, 1200r 9TB SATA Model, 400r 1.2TB SAS Model, 400r 1TB SATA Model, 400r 2TB SATA Model, 400t 1TB SATA Model, 400t 584GB SAS Model , HP StorageWorks Network Storage Gateway X3800 G2 , HP StorageWorks Network Storage System X1400 G2, X1500 G2, X1600 G2, X1800 G2
