- HPE - storage enclosure
- Storage enclosure
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- Supported Drives
- SATA-150 / SAS
- Hard Drive
- 0 HDD - hot-swap
- Designed For
- ProLiant ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry
- Storage enclosure
Chassis
- 0
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-150 / SAS
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 3.5" x 1/3H
- Designed For
- HPE ProLiant ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry
