HP LaserJet Pro P1606DN Mono Laser Printer
HP LaserJet Pro P1606dn Printer
Quicklinx: 6MQPWS00 Mfr#: CE749A#B19
Boost your small office's efficiency with Ethernet networking, automatic two-sided printing and easy-to-use features. Save money and energy with Instant-on Technology. Save even more energy with HP Auto-On/Auto-Off Technology.
  • Handle the printing demands of a busy small office with this fast HP LaserJet printer
    Connect and share this compact printer within a small office, using built-in 10/100 Ethernet networking.Print documents fast at up to 25 ppm A4.Get a first page out in as fast as 7 seconds from Powersave with Instant-on Technology.Choose the media that suits your business purpose as the 250-sheet paper tray and 10-sheet priority input slot handle a wide variety of media types such as card stock, transparencies, labels, envelopes and paper.
  • Stay on task with easy mobile printing and fast setup
    Print from virtually anywhere with HP ePrint. Easily print from smartphones or other Internet-capable devices. And with AirPrint you can simply print wirelessly from your iPad , iPhone , and iPod touch .Set up and start printing right away with an easy-to-use, intuitive control panel.Receive consistent, outstanding results with Original HP cartridges, and easily reorder with HP SureSupply.
  • Choose a printer that helps you save paper, energy and money
    Get up to 50 percent energy savings over competitive laser products, using Instant-on Technology.Save even more with HP Auto-On/Auto-Off Technology which senses your printing activity, turning on and off automatically.Save paper with automatic two-sided printing and reduce wasted paper by printing only the content you want, using HP Smart Web Printing.HP helps reduce your environmental impact with less packaging, plus free cartridge recycling with HP Planet Partners.
  • Make a professional impression with cost-effective laser printing
    Produce professional-quality business prints with bold, crisp text and sharp images.Receive improved print quality with HP FastRes 1200 which delivers smaller print files, crisp text, even tones and smooth business graphics.Save space and reduce printer noise with an ultra-compact, space-saving printer with a "quiet" mode.Support for HP PCL 5e enables effective, reliable processing of documents and helps ensure consistent communication across a wide range of devices.
HP LaserJet Pro P1606DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
7 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 26 ppm - B/W
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, LAN
RAM Installed (Max)
32 MB
Media Type
Envelopes, transparencies, labels, plain paper, photo paper, postcard, card stock, vellum paper
Total Media Capacity
260 sheets
Monthly Duty Cycle (max)
8000 pages
Print server - Ethernet, Fast Ethernet - internal
Microsoft Certification
Compatible with Windows 7
Enclosure Colour
Environmental Standards
EPEAT Silver
1-year warranty
38.7 cm x 28.4 cm x 24.6 cm
Printer Type
Workgroup printer - laser - monochrome
Enclosure Colour
Printer
Print Speed
Up to 26 ppm - B/W
Wired
USB, LAN
1200 dpi
Automatic Duplexing
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 163 g/m²
260 sheets
Media Feeders
1 x automatic - 250 sheets - 216 x 356 mm , 1 x automatic - 10 sheets - 216 x 356 mm
Output Trays Capacity
150 sheets
Duty Cycle
8000 pages
Print server - internal
1 x USB - 4 pin USB Type B
Power supply - internal
Frequency Required
50/60 Hz
440 Watt
Power Consumption Stand by / Sleep
2.2 Watt
Software Included
Drivers & Utilities
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Limited warranty - 1 year
15 °C
33 °C
10 - 80%
Sound Emission (Operating)
53 dBA
38.7 cm
28.4 cm
24.6 cm
7 kg
Width (Shipping)
49.7 cm
Depth (Shipping)
33 cm
Height (Shipping)
33 cm
Weight (Shipping)
9 kg
6MQP HP 78A Black Original LaserJet Toner Cartridge In Stock £68.73
6MQP HP 78A 2-pack Black Original LaserJet Toner Cartridges In Stock £124.88
