Stay productive with affordable wireless printing and impressive mobility
Network the printer without extra cables and access it from virtually anywhere in your home or office, using 802.11 b/g/n wireless connectivity.Print from almost anywhere and stay productive on the go with HP ePrint.Send files from a wireless-enabled smartphone or other Internet-enable device directly to your printer using HP ePrint Wireless Direct printing,.Print wirelessly from your iPad , iPhone , and iPod touch with AirPrint . -
Experience easy, reliable, HP LaserJet printing
Set up and start printing right away with an easy-to-use, intuitive control panel with LED lights.Print documents fast at up to 18 ppm A4 and get a first page out in as fast as 8.5 seconds from Powersave mode (Auto-Off), with Instant-on Technology.Print on a wide variety of media types including card stock, transparencies, labels and envelopes, using the 150-sheet paper tray and 10-sheet priority input slot. -
Reduce your environmental impact with one of the most energy-efficient printers on the planet
Save energy with HP Auto-On/Auto-Off Technology, which senses your printing activity, turning on and off automatically.Reduce wasted paper by printing only the content you want, using HP Smart Print. HP Smart Print delivers more usable web pages by printing web pages without cut-off edges and blank pages.Save space with an ultra-compact printer with a sleek, industrial design.HP helps reduce your environmental impact with less packaging, plus free cartridge recycling with HP Planet Partners. -
Create professional-quality, cost-effective prints
Get improved print quality with HP FastRes 1200 which produces smaller print files, bold, crisp text, even tones, sharp images and smooth business graphics.Validate your cartridge purchase as Original HP to ensure superior performance and reliability. Download HP Cartridge Authentication software to avoid accidentally using counterfeit cartridges.
- HP LaserJet Pro P1102 - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 5.2 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- HP FastRes 1200
- Interface
- USB
- Processor
- 266 MHz
- RAM Installed (Max)
- 2 MB (2 MB)
- Media Type
- Envelopes, transparencies, labels, plain paper, photo paper, postcard, cards, recycled paper, vellum paper
- Total Media Capacity
- 150 sheets
- Monthly Duty Cycle (max)
- 5000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP / 7, Apple MacOS X Server 10.4 or later, Microsoft Windows Server 2008
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 34.9 cm x 23.8 cm x 19.6 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 1200 dpi
- HP FastRes 1200
- First Print Out Time B/W
- 8.5 sec
- Processor
- 266 MHz
RAM
- 2 MB / 2 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 216 mm x 356 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 5000 pages
- 250 - 1500 pages
- Connections
- 1 x USB - 4 pin USB Type B
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 360 Watt
- Power Consumption Stand by / Sleep
- 1.4 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - parts and labour - 1 year
- 15 °C
- 32.5 °C
- 10 - 80%
- 34.9 cm
- 23.8 cm
- 19.6 cm
- 5.2 kg
- Width (Shipping)
- 40 cm
- Depth (Shipping)
- 29.8 cm
- Height (Shipping)
- 25 cm
- Weight (Shipping)
- 6.4 kg
HP 85A 2-pack Black Original LaserJet Toner Cartridges | In Stock | £112.33 |
