Enhance security with plenty of built-in and optional security features, increase productivity with fast print speeds and print from smartphones, tablets or laptops with mobile printing options.
Get intuitive features for a fast finish
Easily manage settings and help keep data secure with built-in features.Easily share this printer using Ethernet connectivity.Connect via USB and access tools from your PC to manage your printer and supplies. -
Just print – protected and connected
Speed through printing tasks using the simple control panel.Work with less wait. Step up your productivity with fast print speeds of up to 26 pages per minute.Start working, right out of the box – full-capacity, 1,500-page toner cartridge included.Print projects without pause – this printer has a 250-sheet input tray plus a 10-sheet priority feed slot. -
Reduce your impact
Help save energy with HP Auto-On/Auto-Off Technology.Print reliably on a wide range of paper types – including office papers as light as 60 GSM.Count on easy, free cartridge recycling through HP Planet Partners.Conserve resources with a printer that's ENERGY STAR qualified and Blue Angel compliant.
- HP LaserJet Pro M201n - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 5.9 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 25 ppm - black normal - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP FastRes 1200
- Interface
- USB 2.0, Gigabit LAN
- AirPrint Enabled
- Processor
- 750 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5C, PostScript, PCL 6, PDF, PCLm
- Media Type
- Envelopes, transparencies, labels, plain paper, photo paper, card stock, postcards, vellum paper
- Total Media Capacity
- 260 sheets
- Media Handling
- 10-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 8000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology
- System Requirements
- Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 SP1 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 32-bit Edition, Microsoft Windows Server 2008 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows Server 2008 R2 SP1 (64-bits), Microsoft Windows 7 32-bit Edition
- 1-year warranty
- 37.9 cm x 24.19 cm x 25.14 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- HP FastRes 1200
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 750 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 76 x 127 mm, 147 x 211 mm, 76 x 187 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 260 sheets
- Media Feeders
- 1 x automatic - 10 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 8000 pages
- 250 - 2000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages
- FCC Class B certified, CISPR 22 Class B, ICES-003, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, IEC 60950-1:2005, GB 17625.1-2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 450 Watt
- Power Consumption Stand by
- 2.2 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows Vista/7/8/8.1/2008 (64 bits) - 1 GHz - RAM 2 GB - HD 400 MB , Windows Vista/7/8/8.1/2008 (32 bits) - 1 GHz - RAM 1 GB - HD 400 MB , Windows Server 2003 - 1 GHz - RAM 1 GB - HD 400 MB , MacOS X 10.7/10.8/10.9 - HD 1 GB
- Limited warranty - 1 year
- 15 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Operating)
- 50 dBA
- 37.9 cm
- 24.19 cm
- 25.14 cm
- 5.9 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 30 cm
- Height (Shipping)
- 35 cm
- Weight (Shipping)
- 8.6 kg
HP 83A Black Original LaserJet Toner Cartridge | In Stock | £56.03 |
