HP LaserJet Pro M1536dnf Mono Laser Multifunction Printer
HP LaserJet Pro M1536dnf Multifunction Printer
Quicklinx: 772KWS00 Mfr#: CE538A#B19
Tackle daily business tasks with a cost-effective, fast HP LaserJet MFP. Print two-sided documents from anywhere, using HP ePrint. Streamline your workflow by copying, scanning, faxing and connecting securely via Ethernet networking.
  • Do more with a fast, networked MFP and two-sided printing
    Stay productive: print at up to 25 ppm A4 and get a first page out in as fast as 8.5 seconds with Instant-on Technology.Share printing resources on a network with built-in 10/100 Ethernet connectivity.Use the 35-page automatic document feeder to print two-sided pages, or to copy and fax multiple-page documents.Save paper and time: fax documents directly to and from a PC and desktop applications, and control access to the faxing features with assigned PINs.
  • Create a variety of high-quality business documents in multiple sizes
    Print professional documents with bold text and sharp images, using Original HP LaserJet print cartridges for consistently excellent quality every time you print.Achieve improved print quality with HP FastRes 1200: bring your documents to life with fine details, solid fills and smooth transitions.Add variety to your documents: the 10-sheet priority tray and 250-sheet paper tray enable you to use a variety of media sizes and types.
  • Print from anywhere and use intuitive features
    Print from anywhere, anytime, with a smartphone, notebook PC or other mobile device, using HP ePrint and print wirelessly from your iPad , iPhone and iPod touch with AirPrint .Simplify printing tasks with an intuitive and easy to navigate control panel and LCD. Use ID Copy to create a one-sided copy of a two-sided ID.Easily find and purchase cartridge replacements with HP SureSupply and install them without hassle.Use embedded HP tools for easy MFP configuration, operation and maintenance.
  • Minimise your environmental impact
    Reduce your impact on the environment, and use up to 50% less paper with two-sided printing.Conserve energy with Instant-on Technology and Instant-on Copy.Get free and easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.Save energy and space with a compact, ENERGY STAR qualified MFP.
HP LaserJet Pro M1536dnf - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Recommended Monthly Volume
500 - 2000 pages
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 25 ppm
Max Printing Resolution
Fax Resolutions
300 x 300 dpi
Scanning
1200 dpi
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
44.1 cm x 34.3 cm x 37.3 cm
11.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 impressions
500 - 2000 pages
Display
2 lines
USB 2.0, LAN
Standard Memory
128 MB 128 MB
Max Supported Memory
128 MB 128 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 25 ppm
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
1200 dpi
Colour Depth
24-bit
Fax Machine
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 400 pages
Fax Machine Features
Broadcast Transmission
119 stations
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Supported Media Type
250 sheets
100 sheets
ADF - 35 sheets weight: 60 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm)
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista
445 watt
Power Consumption Standby
4.7 watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
44.1 cm
34.3 cm
37.3 cm
11.7 kg
Shipping Width
59.7 cm
Shipping Depth
49.7 cm
Shipping Height
46.7 cm
Shipping Weight
14.7 kg
18 °C
25 °C
772K HP 78A Black Original LaserJet Toner Cartridge In Stock £74.07
