HP Laserjet Pro M1212NF MFP
HP LaserJet Pro M1212nf Multifunction Printer
Quicklinx: 7070WS00 Mfr#: CE841A#B19
Tackle your everyday office tasks with an affordable, full-featured MFP. Easily print, copy, scan and fax from one compact device. Share easily with Ethernet networking.
  • Get more done with this affordable, full-featured MFP
    Share on a network using built-in Ethernet connectivity.Create professional-quality documents with bold, crisp text and sharp black-and-white images, using HP Original print cartridges.Send and receive faxes from your PC, using the 33.6 kbps fax.Print documents at up to 18 ppm A4 and get a first page out (from Auto-Off mode) in as fast as 8.5 seconds with Instant-on Technology.
  • Get up and running quickly and easily
    Install in a flash on your PC without a CD, using HP Smart Install which makes it easy to start printing quickly.Set up and start printing fast with an easy-to-use, intuitive control panel.Copy a duplex ID onto one page with ID Copy.Easily connect the MFP directly to a PC via the Hi-speed USB 2.0 port. Ensure reliable printing with an HP all-in-one print cartridge and easily replace it with HP SureSupply.
  • Meet your environmental goals, while protecting your bottom line
    Get up to 50 percent energy savings using Instant-on Technology and save up to four times the energy with Instant-on Copy.Save even more with HP Auto-On/Auto-Off Technology as it senses your printing activity, turning on and off automatically.Reduce your environmental impact as pre-installed cartridges decrease packaging. Recycle easily with HP Planet Partners.Save energy with an ENERGY STAR qualified MFP.
  • Reduce your impact and protect your bottom line
    Conserve energy with HP Auto-On/Auto-Off Technology, Instant-on Technology and Instant-on Copy.Reduce your impact-pre-installed cartridges decrease packaging. Recycle easily with HP Planet Partners.Get the services, solutions, software and support of HP Total Care.Save energy with an ENERGY STAR qualified MFP.
HP LaserJet Pro M1212nf MFP - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 600 x 400 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
150 sheets
Max Media Capacity
100 sheets
Connection Availability
USB 2.0, LAN
43.5 cm x 26.5 cm x 30.6 cm
8.3 kg
Enclosure Colour
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 impressions
Display
2 lines
USB 2.0, LAN
Enclosure Colour
Standard Memory
64 MB 64 MB
Max Supported Memory
64 MB 64 MB
Copying
Max Copying Speed
Up to 18 ppm
Up to 600 x 400 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Image Enhancement Technology
HP FastRes 1200
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 500 pages
Fax Machine Features
Speed Dialing
100 station(s)
Delayed Transmission
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, junk fax barrier
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Max Media Size
A4
Supported Media Type
150 sheets
Max Media Capacity
100 sheets
ADF - 35 sheets weight: 60 g/m² - 90 g/m² , Input tray - 150 sheets - Legal (216 x 356 mm)
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows 7, Apple MacOS X 10.4 or later, MS Windows Vista
375 Watt
Power Consumption Standby
4.7 Watt
ENERGY STAR Certified
Limited warranty - 1 year
43.5 cm
26.5 cm
30.6 cm
8.3 kg
Shipping Width
59.7 cm
Shipping Depth
39.7 cm
Shipping Height
35.1 cm
Shipping Weight
10.8 kg
10 °C
32.5 °C
10 - 80%
7070 HP 85A Black Original LaserJet Toner Cartridge In Stock £64.29
