Finish jobs faster, produce high-impact colour, and get set up and connected quickly. Print from your smartphone or tablet with HP ePrint. Easily conserve resources and recycle used cartridges.
Expand your performance potential
Increase productivity and finish scanning jobs faster with single-pass, dual-head scanning.Print documents at up to 30 pages per minute. Rely on a robust recommended monthly page volume of 1500 to 4000 pages.Convert hard copies to digital files for easy distribution and storage, and make flawless copies.Easily handle jobs to stay productive, using the 50-sheet document feeder and automatic two-sided printing. -
Show off with powerful colour
Simplify workflows: access, store and print business content quickly with an 8.89 cm (3.5-inch) colour touchscreen.Make maximum impact ÔÇô optimise colour settings and get vivid results with incredible resolution.Produce top-notch marketing materials in the office ÔÇô on a broad range of media and in a variety of sizes.Start working fast with preinstalled cartridges. Get better value with optional high-capacity cartridges. -
Enjoy fast, easy set-up and stay connected
Use HP Auto Wireless Connect to configure networking without wires.Print from your smartphone or tablet with HP ePrint. Easily send prints from devices without a network.Use resources more efficiently with wireless and 10/100/1000T Gigabit Ethernet networking ÔÇô access, print, and share.Proactively manage this MFP, using HP Web Jetadmin to monitor office printing and device status remotely. -
Help reduce your environmental impact
Help save energy with HP Auto-On/Auto-Off Technology, Instant-on Copy, and Instant-on Technology.Conserve resources and save paper ÔÇô use automatic two-sided printing.Get centralised, easy access to custom energy-saving options and printer settings with HP EcoSMART Console.Reduce your impact ÔÇô easily recycle Original HP LaserJet toner cartridges through HP Planet Partners.
- HP LaserJet Pro MFP M570dn - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 75000 impressions
- Recommended Monthly Volume
- 1500 - 4000 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, scan to Cloud
- Power
- AC 230 V (50Hz)
- 51.5 cm x 50 cm x 53.8 cm
- 40.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 75000 impressions
- 1500 - 4000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 256 MB 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 250 pages
- PC Faxing
- Yes (send only)
Fax Machine Features
- Speed Dialing
- 120 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76 x 127 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 350 sheets
- 850 sheets
- 100 sheets
- 250 sheets
- Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: A5 (148 x 210 mm) - 216 x 297 mm weight: 60 g/m² - 220 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 250 sheets
- Speed Details
- Printing: up to 30 ppm - B/W normal , Printing: up to 30 ppm - colour normal , Copying: up to 30 ppm - B/W normal , Copying: up to 30 ppm - colour normal , Scanning: up to 19.5 ppm (A4) - B/W normal , Scanning: up to 14 ppm (A4) - colour normal
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- SSL, Apple Bonjour, 802.1x
- Operating System Support
- MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, Sun Solaris 8, Sun Solaris 9, MS Windows 7, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, MS Windows Server 2008, Apple Mac OS X 10.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Linux Linpus Desktop 9.4, Linux Linpus Desktop 9.5, Ubuntu Linux 8.04.1 LTS, Ubuntu Linux 8.04.2 LTS, Apple Mac OS X 10.7, Debian Linux 5.0, MS Windows Server 2003 SP3 or later, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 605 watt
- Power Consumption Standby
- 52 watt
- Power Consumption Sleep
- 8.1 watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 5500 pages , 1 x toner cartridge (yellow/cyan/magenta) - up to 6000 pages
- CISPR 22 Class A, GS, EN55024, EN55022 Class A, EMC, Laser Class 1, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1, GB 17625.1, LVD, EN 61000-3-2:2006, EN 61000-3-3:2008
- ENERGY STAR Certified
- 51.5 cm
- 50 cm
- 53.8 cm
- 40.8 kg
- Shipping Width
- 73.3 cm
- Shipping Depth
- 64.4 cm
- Shipping Height
- 73 cm
- Shipping Weight
- 45.9 kg
- Sound Emission
- 52 dBA (operating)
- 10 °C
- 30 °C
- 10 - 70%
Ink (8)
HP Colour LaserJet CE254A Toner Collection Unit | In Stock | £17.76 |
HP Colour LaserJet CE506A 220V Fuser Kit | In Stock | £176.04 |
HP 507A Black Original LaserJet Toner Cartridge | In Stock | £139.34 |
HP 507A Cyan Original LaserJet Toner Cartridge | In Stock | £207.57 |
HP 507A Yellow Original LaserJet Toner Cartridge | In Stock | £207.57 |
HP 507A Magenta Original LaserJet Toner Cartridge | In Stock | £207.57 |
HP 507X High Yield Black Original LaserJet Toner Cartridge | In Stock | £187.46 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £16.54 |
Other bundles (2)
HP Scanjet ADF Roller Replacement Kit | In Stock | £53.99 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £324.57 |
