HP LaserJet Pro 400 M451dn Colour Laser Printer
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 7ZJ5WS00 Mfr#: CE957A#B19
Ideal for work teams of up to 8 users, who need the convenience of wireless and professional-quality color from an easy-to-use, highly affordable, networked HP LaserJet printer.
Enjoy high productivity with great print speeds and professional-quality colour.
Boost productivity and save time with print speeds of up to 20 ppm A4.
Produce crisp, detailed text and consistently smooth colour with HP ImageREt 3600 and Original HP LaserJet toner cartridges.
Design and produce colour marketing materials in-house on a range of media sizes from 8.9 x 12.7 cm (3.5 x 5 inches) to 21.6 x 35.6 cm (8.5 x 14 inches). Go to www.hp.com/create for tips and templates from HP.
Print documents affordably: get the same black cost per page as a black-and-white HP LaserJet printer[4].
Manage networked resources using convenient, intuitive setup and easy-to-use management features.
Install and proactively manage this printer remotely using HP Web Jetadmin.
Get started right away with HP Smart Install - no CD required[5].
Use the printer anywhere in the office, with built-in wireless connectivity[1]. Share printing on a network with built-in 10/100 Ethernet.
Print from virtually anywhere with HP ePrint[3]. Print from a smartphone directly to your printer using ePrint Wireless Direct printing[6], and print wirelessly from your iPad®, iPhone®, and iPod touch® with AirPrint™[7].
Reduce your environmental impact.
Reduce energy use with HP Auto-On/Auto-Off Technology, which turns the printer on when you need it and off when you don't[8]. Save even more energy with Instant-on Technology[9].
Reduce waste and easily manage paper use with automatic two-sided printing[2].
Save money and print for longer with Original HP high capacity black cartridges[10], and easily reorder with HP SureSupply[11].
Take advantage of free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[12].
[1] Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections. Built-in wireless is available on the HP LaserJet Pro 400 Color M451nw and M451dw only.
[2] Automatic two-sided printing is available on the HP LaserJet Pro 400 M451dn and M451dw only.
[3] Requires an Internet connection to the printer. Feature works with any Internet- and email-capable device. Print times may vary. For a list of supported documents and image types, see http://www.hp.com/go/eprintcenter.
[4] Compared with HP LaserJet Pro P1566/ P1606dn printer. Assuming customer is printing at least 30% of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (http://www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[5] HP Smart Install works with Windows only.
[6] Mobile device must be wireless-enabled and within wireless range of the printer. Printer must be HP ePrint-enabled and may require a firmware upgrade. Feature may require the download of driver or apps to mobile device, available at http://www.hp.com/go/eprintcenter.
[7] Supports iOS 4.2 devices (iPad, iPhone 4, iPhone 3GS, and 3rd and 4th generation iPod touch) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint and iOS 4.2 devices require an 802.11 wireless network connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries.
[8] HP Auto-On/Auto-Off capabilities subject to printer and settings.
[9] Compared with traditional fusing.
[10] HP LaserJet CE410X Black Toner Cartridge not included; please purchase separately.
[11] Programme features and availability may vary by country. For more information, visit http://www.hp.com/learn/suresupply.
[12] Programme availability varies. HP print cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit http://www.hp.com/recycle
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Only the power you need
    Help save energy with HP Auto-On/Auto-Off Technology.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • Ethernet (printer)
    Add this device to your office Ethernet network to share with your workgroup.
HP LaserJet Pro 400 M451dn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
23.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - black normal - A4 (210 x 297 mm) , Up to 20 ppm - colour normal - A4 (210 x 297 mm)
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
600 dpi
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
USB, LAN
600 MHz
RAM Installed (Max)
128 MB (384 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
750 - 2000 pages
Print server - Ethernet, Fast Ethernet
SunSoft Solaris 8, SunSoft Solaris 9, Microsoft Windows XP SP2, Microsoft Windows 7, HP-UX 11, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, SuSE Linux 11, Apple MacOS X 10.6, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Debian GNU/Linux 5.0, Microsoft Windows Vista (64-bit versions), Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Apple MacOS X 10.5, Microsoft Windows Server 2003 SP3 or later, SuSE Linux 10.3, Linux Linpus 9.4, Ubuntu 8.04, Microsoft Windows Server 2008 x64 Edition, Ubuntu 9.10, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Debian GNU/Linux 5.0.1, SuSE Linux 11.x, Ubuntu 10.4
Microsoft Certification
Compatible with Windows 7
1-year warranty
40.5 cm x 48.4 cm x 32.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
600 dpi
600 dpi
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
17 sec
First Print Out Time Colour
17 sec
Language Simulation
Fonts Included
84 x TrueType
Media Handling
600 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
300 sheets
Max Media Capacity
300 sheets
Output Trays Capacity
150 sheets
Duty Cycle
40000 pages
750 - 2000 pages
Print server
Network / Transport Protocol
TCP/IP, BOOTP, DHCP, Bonjour, SLP
Remote Management Protocol
SNMP 1, HTTPS
Security Protocols & Features
SSL, TLS, AES
1 x USB 2.0 , 1 x LAN - RJ-45
EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
Power supply - internal
Frequency Required
50 Hz
295 watt
Software Included
HP ePrint
System Requirements Details
Windows 7/Vista - 1 GHz - RAM 1 GB - HD 400 MB , Windows XP SP2 - Pentium - 233 MHz - RAM 512 MB - HD 400 MB , MacOS X 10.5/10.6 - PowerPC G4 HD 500 MB
Environmental Standards
ENERGY STAR
Limited warranty - replacement - 1 year
15 °C
30 °C
10 - 80% (non-condensing)
Sound Emission (Operating)
51 dBA
40.5 cm
48.4 cm
32.2 cm
23.6 kg
Width (Shipping)
59.5 cm
Depth (Shipping)
49.5 cm
Height (Shipping)
46.2 cm
Weight (Shipping)
28.2 kg
7ZJ5 HP 305A Black Original LaserJet Toner Cartridge In Stock £78.98
7ZJ5 HP 305X High Yield Black Original LaserJet Toner Cartridge In Stock £96.93
7ZJ5 HP 305A Cyan Original LaserJet Toner Cartridge In Stock £112.42
7ZJ5 HP 305A Yellow Original LaserJet Toner Cartridge In Stock £112.42
7ZJ5 HP 305A Magenta Original LaserJet Toner Cartridge In Stock £112.51
7ZJ5 HP 305A 3-pack Cyan/Magenta/Yellow Original LaserJet Toner Cartridges In Stock £321.49
