Print professional-quality color documents on a low-cost, easy-to-use HP LaserJet. Get up and running quickly with HP smart install. Increase productivity with fast print speeds and get the same black cost per page as a black-only HP LaserJet.
Make an impression with professional colour documents and marketing materials created in-house.
Get professional, accurate results: HP ImageREt 3600 and Original HP LaserJet toner cartridges enable exceptional colour and crisp, detailed text.
Design and produce your own marketing materials on a range of media sizes from 8.9 x 12.7 cm (3.5 x 5 inches) to 21.6 x 35.6 cm (8.5 x 14 inches).
Do more from your desktop: go to www.hp.com/create to access ideas, use tips and download templates and stock photos from HP.
Print documents affordably: get the same black cost per page as a black-and-white HP LaserJet printer[2].
Boost productivity and enjoy convenient, intuitive setup and easy-to-use features.
Enjoy high productivity and save time with great print speeds of up to 18 ppm A4.
Install the printer in only a few minutes - HP Smart Install makes it easy to quickly start printing on a PC or netbook, without a CD[1].
Get consistent results and print for longer with Original HP high-capacity black cartridges[3] and easily reorder with HP SureSupply[4]. One easy-access door lets you replace cartridges quickly and simply.
Easily see printer status and navigate the intuitive two-line control panel.
Reduce your environmental impact.
Reduce energy use with HP Auto-On/Auto-Off Technology, which turns the printer on when you need it and off when you don't[5].
Save energy with Instant-on Technology - an innovative, quick-heating fuser system that warms rapidly and cools quickly[6].
Take advantage of free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly[7].
Get centralised, easy access to custom, energy-saving options and printer settings, and reduce your paper use with HP EcoSMART Console.
[1] HP Smart Install works with Windows only.
[2] Compared with HP LaserJet Pro P1566/ P1606dn printer. Assuming customer is printing at least 30% of total pages in colour with content similar to the colour ISO/IEC 19798 test suite (www.iso.org/jtc1/sc28) and overall average job length of three pages. Yields established using ISO/IEC test standards. Actual yields and costs vary considerably depending on images printed, number of colour pages printed, and other factors.
[3] HP LaserJet CE305X Black Toner Cartridge not included; please purchase separately.
[4] Programme features and availability may vary by country. For more information, visit www.hp.com/learn/suresupply.
[5] HP Auto-On-Auto-Off capabilities subject to printer and settings.
[6] Compared with traditional fusing.
[7] Programme availability varies. HP print cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit www.hp.com/recycle
Get professional, accurate results: HP ImageREt 3600 and Original HP LaserJet toner cartridges enable exceptional colour and crisp, detailed text.Design and produce your own marketing materials on a range of media sizes from 8.9 x 12.7 cm (3.5 x 5 inches) to 21.6 x 35.6 cm (8.5 x 14 inches).Print documents affordably: get the same black cost per page as a black-and-white HP LaserJet printer. -
Enjoy high productivity and save time with great print speeds of up to 18 ppm A4.Get consistent results and print for longer with Original HP high-capacity black cartridges and easily reorder with HP SureSupply. One easy-access door lets you replace cartridges quickly and simply.Easily see printer status and navigate the intuitive two-line control panel. -
Reduce energy use with HP Auto-On/Auto-Off Technology, which turns the printer on when you need it and off when you don't.Save energy with Instant-on Technology – an innovative, quick-heating fuser system that warms rapidly and cools quickly.Take advantage of free, easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.Get centralised, easy access to custom, energy-saving options and printer settings, and reduce your paper use with HP EcoSMART Console.
- HP LaserJet Pro 300 M351a - printer - colour - laser
- Printer Type
- Personal printer - laser - colour
- 22.7 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - black normal - A4 (210 x 297 mm) , Up to 18 ppm - colour normal - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Interface
- USB
- Processor
- 600 MHz
- RAM Installed (Max)
- 128 MB (384 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 500 - 1500 pages
- System Requirements
- SunSoft Solaris 8, SunSoft Solaris 9, Microsoft Windows XP SP2, Microsoft Windows 7, HP-UX 11, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, SuSE Linux 11, Apple MacOS X 10.6, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Debian GNU/Linux 5.0, Microsoft Windows Vista (64-bit versions), Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Apple MacOS X 10.5, Microsoft Windows Server 2003 SP3 or later, SuSE Linux 10.3, Linux Linpus 9.4, Ubuntu 8.04, Microsoft Windows Server 2008 x64 Edition, Ubuntu 9.10, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Debian GNU/Linux 5.0.1, SuSE Linux 11.x, Ubuntu 10.4
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 40.5 cm x 45.4 cm x 32.2 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB
- 600 x 600 dpi
- 600 x 600 dpi
- HP ImageREt 3600
- First Print Out Time B/W
- 17 sec
- First Print Out Time Colour
- 17 sec
- Fonts Included
- 84 x TrueType
- Media Handling
- Processor
- 600 MHz
RAM
- 128 MB / 384 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 300 sheets
- Max Media Capacity
- 300 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- 500 - 1500 pages
- Connections
- 1 x USB 2.0
- EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 410 Watt
- Power Consumption Stand by / Sleep
- 15.7 Watt
- OS Required
- System Requirements Details
- Windows 7/Vista - 1 GHz - RAM 1 GB - HD 400 MB , Windows XP SP2 - Pentium - 233 MHz - RAM 512 MB - HD 400 MB , MacOS X 10.5/10.6 - PowerPC G4 HD 500 MB
Environmental Standards
- ENERGY STAR
- Limited warranty - replacement - 1 year
- 15 °C
- 30 °C
- 10 - 95%
- Sound Emission (Operating)
- 51 dBA
- 40.5 cm
- 45.4 cm
- 32.2 cm
- 22.7 kg
- Width (Shipping)
- 59.5 cm
- Depth (Shipping)
- 49.5 cm
- Height (Shipping)
- 46.2 cm
- Weight (Shipping)
- 27 kg
HP 305A Black Original LaserJet Toner Cartridge | In Stock | £74.12 |
HP 305X High Yield Black Original LaserJet Toner Cartridge | In Stock | £91.04 |
HP 305A Cyan Original LaserJet Toner Cartridge | In Stock | £105.59 |
HP 305A Yellow Original LaserJet Toner Cartridge | In Stock | £104.61 |
HP 305A Magenta Original LaserJet Toner Cartridge | In Stock | £104.61 |
HP 305A 3-pack Cyan/Magenta/Yellow Original LaserJet Toner Cartridges | In Stock | £293.96 |
