HP LaserJet P2055 - Printer - B/W - laser - USB
HP LaserJet P2055d Printer
Quicklinx: 6NZRWS00 Mfr#: CE456A#B19
Boost your workteam with the HP LaserJet P2050 Printer Series. Create high quality documents with 1200 dpi, at fast speeds of up to 33 ppm. Performance features include expandable memory, automatic two-sided printing and Gigabit networking.
  • Get more done in less time with this high performance HP LaserJet
    Get print speeds of up to 33 ppm A4 and a fast first page out from low power mode with no wait Instant-on Technology.Save time and paper with convenient automatic two-sided printing.Quickly and accurately process complex print jobs with a 600 MHz processor and expandable memory.Enjoy reliable sharing and efficiently utilise printing resources with high speed connectivity via built-in Gigabit networking.Easily connect the printer to your computer with the Hi-Speed USB 2.0 port.
  • Create professional quality output with this compact printer
    Achieve professional quality with true 1200 dpi resolution for crisp text, fine lines and sharp images, every time you print.Adjustable paper trays help you easily print a variety of black-and-white documents in all sizes from A6 to A4 (from all trays).Save valuable desktop space and enjoy convenient access to the printer with its sleek, compact design.The high yield, All-in-one HP LaserJet print cartridge is designed for simplicity and delivers consistently great results.
  • Easy to set up, use and maintain
    Navigation is intuitive with the LCD control panel.Experience fewer interruptions with a 250-sheet input tray, 50-sheet multipurpose tray and optional 500-sheet tray.Conveniently order supplies with HP SureSupply.HP Web Jetadmin enables access to printer status, alerts, configuration settings and more. HP Universal Print Driver increases ease of use and productivity.Interactive intelligence built into the HP print cartridge enables alerts when supplies are low, making management easy.
HP LaserJet P2055 - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 33 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
USB
600 MHz
RAM Installed (Max)
64 MB (384 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cards, glossy paper
Total Media Capacity
300 sheets
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 3000 pages
UNIX, Novell NetWare, Linux, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Apple MacOS X 10.4, Apple MacOS X 10.3.9, Microsoft Windows Vista, Apple MacOS X 10.5.x
Microsoft Certification
Works with Windows Vista
1-year warranty
36.6 cm x 36.8 cm x 26.8 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB
1200 dpi
First Print Out Time B/W
8 sec
Language Simulation
Fonts Included
45 x TrueType , 35 x PostScript
600 MHz
RAM
RAM Installed (Max)
64 MB / 384 MB (max)
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), A4 Long (210 x 348 mm)
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
750 - 3000 pages
1 x USB 2.0
Consumables Included
1 x toner cartridge (black)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
Power supply - internal
Frequency Required
50/60 Hz
570 Watt
Power Consumption Stand by / Sleep
8 Watt
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 1 year
17.5 °C
25 °C
30 - 70%
36.6 cm
36.8 cm
26.8 cm
9.9 kg
Width (Shipping)
48.1 cm
Depth (Shipping)
67.7 cm
Height (Shipping)
26.8 cm
Weight (Shipping)
12.4 kg
