Enhance productivity and get great value for money with this black-and-white HP LaserJet
Enjoy fast print speeds of up to 30 ppm and get a fast first page out from low power mode with Instant-on Technology.Conveniently connect your printer to a computer using the USB or parallel port.Print a variety of office documents of almost any length, with a 250-sheet input tray; the 50-sheet multipurpose tray supports a variety of print media.Process complex files quickly with a 266 MHz processor and 16 MB memory. -
Achieve impressive, professional quality results with this conveniently compact printer
Print professional-quality documents with crisp text and sharp images thanks to HP FastRes 1200 which provides 1200 dpi effective output quality.This sleek, space-saving printer's compact design ensures that it fits conveniently into a small area of the desktop.Reduce operation noise with the printer's unique Quiet mode.The reliable all-in-one HP LaserJet print cartridge is designed to meet your usage needs, optimise print quality and provide excellent value. -
Extremely easy to set up, use, and maintain
Interactive intelligence built into the Original HP print cartridge optimises print quality and provides alerts when supplies are low, making management straightforward.One-door access to the easy-to-install HP LaserJet Print Cartridge means installation and replacement are simple and convenient.Easily navigate printer functions with the simple LED control panel. -
You'll hardly notice it's there
Select quiet mode to reduce printer operation noise.Easily print a range of media sizes including cards and prescription-size forms.
- HP LaserJet P2035 - printer - monochrome - laser
- Printer Type
- Workgroup printer - laser - monochrome
- 9.9 kg
- Localisation
- English / United Kingdom
- Max Media Size (Standard)
- Legal
- Print Speed
- Up to 30 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution ( B&W )
- 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Interface
- Parallel, USB
- Processor
- 266 MHz
- RAM Installed ( Max )
- 16 MB ( 16 MB )
- Language Simulation
- PCL 5E
- Media Type
- Envelopes, transparencies, labels, plain paper, glossy paper, cards
- Total Media Capacity
- 300 sheets
- Monthly Duty Cycle (max)
- 25000 pages
- Power
- AC 120 V
- System Requirements
- UNIX, Novell NetWare, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.4.3, Microsoft Windows Vista, Apple MacOS X 10.5.x
- Microsoft Certification
- Certified for Windows Vista
- 1 year warranty
- 36.6 cm x 36.8 cm x 25.7 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- PCL 5E
- Fonts Included
- 45 x TrueType
- Processor
- 266 MHz
RAM
- 16 MB / 16 MB (max)
Media Handling
- Media Type
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm)
- 300 sheets
- Media Feeder(s)
- 1 x autoload - 50 sheets - Legal (216 x 356 mm) , 1 x autoload - 250 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 25000 pages
- Connections
- 1 x USB 2.0 , 1 x parallel
- Consumables Included
- 1 x toner cartridge ( black )
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, IEC 825-1/EN 60825-1 class 1, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1
- Power Device
- Power supply - internal
- Voltage Required
- AC 220 to 240 V
- Frequency Required
- 50 Hz
- 550 Watt
- Power Consumption Stand by / Sleep
- 7 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year - on-site - response time: next business day
- 17.5 °C
- 25 °C
- 30 - 70%
- 36.6 cm
- 36.8 cm
- 25.7 cm
- 9.9 kg
HP 05A Dual Pack Black Toner Cartridge for LaserJet P2035/P2055 | In Stock | £159.36 |
