HP LaserJet Enterprise 500 M551dn Colour Laser Printer
HP Color LaserJet Enterprise 500 M551dn
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 7VV9WS00 Mfr#: CF082A#B19
Affordable, business-enhancing colour from an HP LaserJet that's easy to manage and use. Produce professional-quality colour marketing materials and more. Maximise your investment with expandability options. Count on HP for energy-saving features.
  • Make your business look its best with high-performance colour
    Create marketing materials with realistic colour and crisp detail thanks to PANTONE colour matching and HP Easy Color.Increase colour accuracy with HP ImageREt 3600 and HP ColorSphere toner technology.Achieve low-cost, high-quality printing right out of the box, with a complete set of cartridges – on average, nearly two times more black toner and more than two times the colour toner of leading competitors.Print black text affordably, using an optional high-capacity black print cartridge,.
  • Invest in a printer that's as easy to use as it is to manage
    Manage jobs directly from the printer's four-line colour control panel, and easily print from a USB flash drive.Make printing as mobile as you are with HP ePrint – now you can print from virtually anywhere.Keep confidential information secure by requiring a PIN to retrieve print jobs and protect data with the HP High-Performance Secure Hard Disk.Easily control colour usage with HP Color Access Control, and proactively manage printing environments with industry-leading HP Web Jetadmin.
  • Take advantage of inventive expandability options
    Easily update, manage and extend printer capabilities, using HP FutureSmart Firmware.Take advantage of the HP Solutions Business Partners programme, enabling you to access HP certified solutions from industry-leading partners.Incorporate optional productivity and security solutions easily, using the hardware integration pocket,.Improve productivity: this workhorse colour laser printer gives you up to 1,100-sheet capacity to save time and complete large print jobs without reloading.
  • Enjoy outstanding energy and paper savings
    Reduce energy use by 19% to 66% by setting the Auto-On/Auto-Off mode. Save even more energy with Instant-on Technology which speeds warm-up and cool-down times.Save time with convenient cartridge installation, and get free, easy cartridge recycling.Conserve resources and get up to 50% paper-savings using automatic two-sided printing.
HP LaserJet Enterprise 500 M551dn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
34.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 32 ppm - B/W - A4 (210 x 297 mm) , Up to 32 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
Automatic Duplexing
USB, Gigabit LAN
ARM Cortex-A8 800 MHz
RAM Installed (Max)
1 GB (1 GB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF 1.4
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, cards, heavy-weight glossy paper, bond paper, recycled paper, glossy paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
1500 - 5000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.6, Microsoft Windows Server 2008, Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
1-year warranty
51.4 cm x 49.1 cm x 40.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
1200 dpi
1200 dpi
Automatic Duplexing
PostScript Support
Included
First Print Out Time B/W
11 sec
First Print Out Time Colour
11 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
600 sheets
Max Media Capacity
1100 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
1500 - 5000 pages
Print server
Network / Transport Protocol
IPSec
1 x USB 2.0 - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 - 4 pin USB Type B
UL, cUL, EN 61000-3-2, GS, EN 61000-3-3, CISPR 22, IEC 60950-1, EN 60950-1, IEC 60825-1, FCC CFR47 Part 15 B, EN 60825-1
Power supply - internal
Frequency Required
50 Hz
605 watt
Power Consumption Stand by / Sleep
6.9 watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
10 °C
30 °C
10 - 70%
Sound Emission (Operating)
44 dBA
Sound Emission (Quiet Mode)
66 dBA
51.4 cm
49.1 cm
40.2 cm
34.6 kg
Width (Shipping)
72.5 cm
Depth (Shipping)
60 cm
Height (Shipping)
50 cm
