HPE KVM Server Console Switch G2
Quicklinx: 757XWS00 Mfr#: AF618A
Looking for a simple and intuitive solution that allows you to access and manage servers across your entire network? HP KVM Analog Console Switches allow you to view and manage up to 256 rackmount servers across your data center through a single user interface. Utilizing a local On-Screen Display (OSD) interface, accessed through a rack console such as the HP LCD8500, the switch provides intuitive menus for accessing each attached server or serial managed device. HP's KVM Analog Console Switches support an optional USB Remote Access Key that allows you to upgrade to KVM-over-IP functionality, providing remote access and management via the On-Board Web Interface (OBWI). Available in 8 and 16-Port versions, standard rack mounting of the KVM Analog Console Switch will share 1U (1.75") of front panel rack space with the rack console. However, each model can also be mounted in a "zero U" profile by mounting in the side rails of the rack.
  • View and Manage up to 1024 Servers Through a Single User Interface Locally and Remotely
    HPE Enterprise Analog KVM models include 16 and 32-port models with multiple installation and server connection options.View and manage servers across your data center through a single user interface.Some models support optional USB Remote Access Key to upgrade to KVM-over-IP.Local OSD interface accessed through a KVM console provides menus for accessing attached servers or serial managed devices.1U design leaves room to mount HPE Enterprise Analog KVM models. Also, rails are provided for side mount to save U space in the rack.
  • Increase Efficiency and Save Space While Enabling Easy Scalability Throughout Your Data Center
    HPE Enterprise Analog KVM console switches with virtual media include On-Board Web Interface (OBWI) for remote access and management.Programmable scanning allows you to evaluate system performance.Support for HPE Location Discovery Services and Power Discovery Services with connected to optional HPE Intelligent Power Distribution Unit.Support for variety of server connections with Interface Adapters - PS/2, USB, VT 100 serial console support, and BladeSystems support via front diagnostics connector.
  • Multi-user KVM Console Switches Add Flexibility and Efficiency
    HPE Enterprise Analog KVM console switches with virtual media include two user ports for multiple user consoles, multiple system ports offer expanded flexibility.Simultaneous control of servers in the data center and in remote locations.Support for a multiple network administrators to access all servers in their data center to diagnose problems from separate locations.For protection against unauthorized users, the switch box provides a password option for security purposes.
HPE Server Console G2 Switch with Virtual Media and CAC 0x2x16 - KVM switch - 16 ports
KVM switch - 16 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
2 local users
Firmware upgradable
Power Redundancy
43.8 cm x 23.7 cm x 4.4 cm
3.2 kg
3-year warranty
HPE 10XXX G2, 600, 800; BLc7000 Platinum Single-Phase Enclosure; ProLiant DL120 Gen9, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 G6, DL380 Gen9, DL60 Gen9, DL80 Gen9, e2000 G6, m350, m400, m710, m800, ML110 Gen9, ML150 Gen9, ML350 Gen9, ML350p Gen8; Rack
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
2 local users
Keyboard / Mouse Interface
USB
Max Resolution
1600 x 1200
Firmware upgradable
16 x KVM RJ-45 , 1 x RJ-45 management , 2 x keyboard (USB) Type A , 2 x mouse (USB) Type A , 2 x VGA HD-15 , 1 x LAN RJ-45 , 4 x USB Type A
Internal power supply
Power Redundancy
Power Redundancy Scheme
1+1
43.8 cm
23.7 cm
4.4 cm
3.2 kg
Limited warranty - 3 years
10 °C
50 °C
20 - 80%
HPE 10642 G2 1200mm deep Shock Rack, 10647 G2 1200mm deep Shock Rack, 600mm x 1075mm Advanced Pallet Rack, 600mm x 1075mm Advanced Shock Rack, 600mm x 1075mm Enterprise Crate Rack, 600mm x 1075mm Enterprise Pallet Rack, 600mm x 1075mm Enterprise Shock Rack, 600mm x 1200mm Advanced Pallet Rack, 600mm x 1200mm Advanced Shock Rack, 600mm x 1200mm Enterprise Air Duct Rack, 600mm x 1200mm Enterprise Pallet Rack, 600mm x 1200mm Enterprise Shock Network Rack, 600mm x 1200mm Enterprise Shock Rack, 600mm x 1200mm Grey Enterprise Air Duct Rack, 600mm x 1200mm Grey Enterprise Shock Rack, 600mm x 1200mm Network Advanced Shock Rack, 800mm x 1075mm Enterprise Pallet Rack, 800mm x 1075mm Enterprise Shock Rack, 800mm x 1200mm Advanced Pallet Rack, 800mm x 1200mm Advanced Shock Rack, 800mm x 1200mm Enterprise Pallet Rack, 800mm x 1200mm Enterprise Shock Network Rack, 800mm x 1200mm Enterprise Shock Rack, 800mm x 1200mm Grey Enterprise Shock Network Rack, 800mm x 1200mm Grey Enterprise Shock Rack, 800mm x 1200mm Network Advanced Shock Rack , HPE BLc7000 Platinum Single-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 OneView Licenses , HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8 v2 Entry, DL360 Gen9 Base, DL360 Gen9 Entry, DL360 Gen9 Performance, DL360p Gen8, DL360p Gen8 CMS, DL380 G6, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, e2000 G6, m350, m400, m710, m800, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350p Gen8 , HPE Rack
