HPE KVM Console USB Virtual Media CAC Interface Adapte
Quicklinx: 7271WS00 Mfr#: AF623A
The HP Server Console switch integrates KVM and serial devices into a single management console for all your servers, network devices and infrastructure. Requiring no software to be installed on the target servers the HP Server Console switch provides a true KVM solution for local system management. Tiering support for the HP Server Console switches and the previous generation of legacy KVM switches means that to 256 servers can be managed from a single KVM console. Utilizing Cat5 UTP cables between the switch and server, facilitates cable routing and allows for field termination of custom cable lengths. Integration with the HP IP Console switch ensures that the local KVM solution can be integrated smoothly and easily into a KVM/IP remote management solution.
HP BladeSystems Cat5 KVM interface adapter allows KVM connections to individual HP BladeSystem BL servers. Serial interface adapter integrates devices that use a serial console into the KVM network.
HPE USB Virtual Media CAC Interface Adapter - video / USB extender
Video / USB extender
External
HP TFT7600 G2; ProLiant DL160 G6, DL160 G6 Special Server; Rack; Server Console Switch
External
Wired
1 x network - RJ-45 female , 1 x VGA - HD-15 male , 1 x USB - Type A male
HP TFT7600 G2 , HPE ProLiant DL160 G6, DL160 G6 Special Server , HPE Rack , HPE Server Console Switch
