HPE JetDirect 635N
HPE JetDirect 635N
Quicklinx: 4RR4WS00 Mfr#: J7961G#UUS
Share supported peripherals over your network with one of the first Gigabit EIO print servers to support IPv6, IPv4 and IPsec. Rely on advanced network technology and security, and get data transmission at Gigabit speeds (up to 1000 Mbit per second).
  • Experience robust, next-generation network security with IPsec
    Share printing over your network with one of the first gigabit EIO print servers to support IPv6, IPv4 and IPsec. Rely on advanced authentication and encryption, with data transmission at gigabit speeds (up to 1,000 Mb/sec).
  • Prepare for the future with a scalable and upgradeable solution
    Now you can rely on next-generation network security with robust encryption and authentication while enjoying the network advancements built into IPv6.
  • Extremely easy to install and use
    You're ready for tomorrow's network needs, with a scalable and firmware-upgradeable solution that relies on the new TCP/IP protocol (IPv6) and network security (IPsec). Flash-upgradeable firmware enables you to add future enhancements.
HP JetDirect 635n - print server - EIO - Gigabit Ethernet
Print server
Plug-in module
Interface (Bus) Type
EIO
Ports
Gigabit Ethernet
8.9 cm x 13.6 cm x 3.1 cm
70 g
English, Italian, Swedish, Spanish / Denmark, Finland, Norway, Portugal, Spain, Sweden, United Kingdom, Ireland
Cabling Type
Ethernet 10Base-T, Ethernet 1000Base-TX, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 1GbE
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, DLC/LLC, IPSec
RAM
32 MB
IEEE 802.3, IEEE 802.1x
Microsoft Windows 98, Microsoft Windows NT 4.0, Novell NetWare 3.2, HP-UX 10.20, SunSoft Solaris 2.6, SunSoft Solaris 7, Novell NetWare 4.2, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, SunOS 4.1 or later, Microsoft Windows 2000, HP-UX 11.x, Apple MacOS 8.6 or later, SunSoft Solaris 8, HP MPE/iX, SGI Irix 6.x, Novell NetWare 5.x, Digital UNIX 4.0 or later, SuSE Linux 6.x, Microsoft Windows Millennium Edition, Citrix Presentation Server, Microsoft Windows XP, Novell NetWare 6, Microsoft Windows XP 64-bit Edition, Red Hat Linux 7.x, UnixWare 7.x, Red Hat Linux 6.x, Microsoft Windows Server 2003, SCO OpenServer 5.x, IBM OS/2 Warp 4.x
1-year warranty
Color LaserJet CM4730, CM6030, CP3505, CP3525, CP6015; Color LaserJet Enterprise CP5525; DesignJet 111, 4020, 45XX, 510, 5100, T1100, T1120, T1200, T1300, T2300, T610, T620, T770, T790, Z6100, Z6200; LaserJet 5200, M3035, M9040, M9050, P4014, P4015, P4515; LaserJet Enterprise M4555, M5039, P3015
Print server
Plug-in module
EIO
Ports
Gigabit Ethernet
Wired
Cabling Type
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, NCP, SNMP 2c, HTTP, NDPS, NDS, HTTPS
DHCP support, BOOTP support, firmware upgradable
Processor / Memory
RAM
32 MB
Flash Memory
8 MB
1 x 1000Base-TX - RJ-45
Compatible Slots
1 x EIO
Encryption Algorithm
SSL, TLS, PEAP
FCC Class A certified, DOC, AS/NZS 3548
Software Included
Drivers & Utilities
8.9 cm
13.6 cm
3.1 cm
70 g
Shipping Width
15.3 cm
Shipping Depth
22.3 cm
Shipping Height
5.7 cm
Shipping Weight
0.2 kg
Limited warranty - 1 year
55 °C
0 - 95%
HP Business Inkjet 2300, 2300dtn, 2300n , HP Color LaserJet 3000, 3000dn, 3000dtn, 3000n, 3800, 3800dn, 3800dtn, 3800n, 4700, 4700dn, 4700dtn, 4700n, 4700ph+, 9500hdn, 9500n, CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP, CM6030 MFP, CM6030f MFP, CP3505, CP3505dn, CP3505n, CP3505x, CP3525, CP3525dn, CP3525n, CP3525x, CP6015dn, CP6015n , HP Color LaserJet Enterprise CP5525dn, CP5525n, CP5525xh , HP DesignJet 111, 4020, 4020ps, 4500ps, 4520, 4520 HD-MFP, 4520ps, 510, 5100, 510ps, T1100, T1100 MFP, T1100ps, T1120, T1120 HD-MFP, T1120 SD-MFP, T1120ps, T1200, T1200 HD-MFP, T1200ps, T1300 ePrinter, T1300 PostScript ePrinter, T2300 PostScript eMultifunction Printer, T610, T620, T770, T770 Hard Disk Version, T790 ePrinter, T790ps ePrinter, Z6100, Z6100ps, Z6200 , HP LaserJet 4240n, 4250, 4250dtn, 4250dtnsl, 4250n, 4250tn, 4350, 4350dtn, 4350dtnsl, 4350n, 4350tn, 5200, 5200dtn, 5200L, 5200n, 5200tn, 9040, 9040dn, 9040n, 9050, 9050dn, 9050n, M3027 MFP, M3027x MFP, M3035 MFP, M3035xs MFP, M4345 MFP, M4345x MFP, M4345xm MFP, M4345xs MFP, M5025 MFP, M5035 MFP, M5035x MFP, M5035xs MFP, M9040 MFP, M9050 MFP, P3005, P3005d, P3005dn, P3005n, P3005x, P4014dn, P4015n, P4015tn, P4015x, P4515n, P4515x , HP LaserJet Enterprise M4555 MFP, M4555f MFP, M4555fskm MFP, M4555h MFP, M5039xs MFP, P3015, P3015d, P3015dn, P3015n, P3015x
