Two-button mouse with scroll wheel that provides the speed and accuracy of optical tracking in a simple, elegant design. Has no ball or moving parts, which improves its durability, makes it require less cleaning, and eliminates sticking.
- HP DC172B - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- 6.3 cm x 11.6 cm x 3.8 cm
- 120 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 800 dpi
- Scrolling wheel
- Cables Included
- 1 x USB cable - integrated - 1.85 m
- OS Required
- Microsoft Windows 95/98, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP
- 1-year warranty
- Mouse
- 6.3 cm
- 11.6 cm
- 3.8 cm
- 120 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 800 dpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- Cables Included
- OS Required
- Limited warranty - replacement - 1 year
