Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
Tower UPS Models Provide Power Protection and Management Optimized for Smaller IT Environments
HP Line Interactive Single Phase Uninterruptible Power System Tower models lower your power protection cost by providing up to eight (8) power outlets per UPS, allowing you to safeguard your IT and office equipment.Standard features include an intuitive front panel display, Enhanced Battery Management (EBM), Network Transient Protection, and serial and USB ports for data exchange with the host computer.Support hot-swappable battery packs that allow you to safely install a new battery without ever powering down connected computer equipment.Includes (at no additional cost) HP Power Manager software that provides the flexibility to monitor power conditions and control the HP UPS locally or remotely.Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty. -
Flexible Rack/Tower Models Deliver Cost-Effective Power Protection Inside and Outside of the IT Rack
HP Line Interactive Single Phase Uninterruptible Power System Rack/Tower (R/T) models can be used in a traditional rackmount environment or converted to a tower UPS to support tower servers and other equipment outside of an IT rack.Support up to four (4) Extended Runtime Modules (ERM) to increase battery run time during a power outage.Standard features include an enhanced front panel display, HP Enhanced Battery Management (EBM) to easily manage and extend the service life of your batteries, and hot-swappable batteries that can be serviced while the UPS is in operation.HP Power Protection software (included) and an UPS Network Module (optional) enable you to monitor and manage power through HP Systems Insight Manager and other SNMP management programs or via a standard web browser.Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty. -
Ultra-Dense Rack UPS Models Scale from Small to Enterprise IT Environments
HP Line Interactive Single Phase Uninterruptible Power System Rackmount models provide from 1.5kVA (R1500 G4) up to 7.2kVA (R7000) of output power in as little as 4U of rack space.Support up to four (4) Extended Runtime Modules (ERM) to increase battery run time during a power outage (R5000 and R7000 only).Support hot-swappable battery packs that allow you to safely install a new battery without ever powering down connected computer equipment.The R5000 and R7000 include both HP Power Protection software and an UPS Network Module that enable you to monitor and manage power through HP Systems Insight Manager and other SNMP management programs or via a standard web browser (UPS Network Module optional on R1500 G4).Backed by a 3-year limited warranty and an exclusive 30-day Battery Pre-Failure Warning providing notification from HP Power Manager software of an impending battery failure and free replacement while under the warranty.
- HPE UPS R/T3000 G2 Detachable Cord High Voltage - UPS - 3 kW - 3300 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 37 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- + 6% / - 10%
- Power Capacity
- 3 kW / 3300 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 6 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid - 5 Ah
- Batteries Qty
- 1
- Run Time (Up To)
- 4 min at full load
- Networking
- RS-232, USB
- Included Accessories
- Floor stand, rack to tower conversion kit
- 44.5 cm x 63.5 cm x 8.9 cm
- 3-year warranty
- Designed For
- Apollo 4510 Gen9; ProLiant DL120 G7, DL160 Gen8, DL165 G7, DL360 G7, DL360e Gen8, DL360p Gen8, DL380 G7, DL380p Gen8, DL385p Gen8, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8, ML330 G6, ML350 G6, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL270s Gen8; Rack
- Height (Rack Units)
- 2U
- UPS Technology
- On-line
- Input Voltage
- AC 220/230/240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- + 6% / - 10%
- Power Capacity
- 3 kW / 3300 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Quantity
- 1
- Technology
- Lead Acid
- Capacity
- 5 Ah
- Run Time (Up To)
- 40 min at 20% load , 12 min at half load , 6 min at 80% load , 4 min at full load , 125 min at 20% load with extended capacity battery , 50 min at half load with extended capacity battery , 30 min at 80% load with extended capacity battery , 24 min at full load with extended capacity battery , 225 min at 20% load with two extended capacity batteries , 99 min at half load with two extended capacity batteries , 60 min at 80% load with two extended capacity batteries , 47 min at full load with two extended capacity batteries
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type A
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Cables Included
- Serial cable - external , USB cable - external , Power cable - detachable
- Rack Mounting Kit
- Included
- Remote Power Off, LED indicators, hot-swappable batteries
- UL, GOST, cUL, GS, UL 1778, IEC 62040-1-1, UL 60950-1, EN 60950-1, WEEE
- Software Included
- HP Power Protector (free download)
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 45 dB
- 44.5 cm
- 63.5 cm
- 8.9 cm
- 37 kg
- Shipping Width
- 59.6 cm
- Shipping Depth
- 92.1 cm
- Shipping Height
- 28.6 cm
- Shipping Weight
- 40.4 kg
- Designed For
- HPE Apollo 4510 Gen9 , HPE ProLiant DL120 G7, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL165 G7 Base, DL360 G7, DL360e Gen8, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Base, SL210t Gen8 1U Node, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray , HPE Rack
