HPE Half-Height SATA DVD-RW Optical Kit
Quicklinx: 75GDWS00 Mfr#: 624192-B21
  • DVD-RW
The DVD RW drive is capable of reading DVD 4.7 GB through 8.5 GB media. It can also read standard stamped, CD-R, and CD-RW media. This drive supports writing to CD-R, CD-RW, DVD +R/RW, and DVD -R/RW media via software utilities. For Microsoft operating systems, this is available by installing the included Roxio software disk. For other operating systems, an operating system-specific software utility is required for writing to media. The DVD-ROM drive is designed to read not only CD-ROM and CD -R/RW discs but also DVD-ROM, DVD-RAM, DVD +R/RW and DVD -R/RW discs.
  • Typical Customers are Those Who
    Want to perform local back up or retail/branch office configuration archiving.Want to locally install software/patches or load data.Require an OS boot disk that is larger than traditional floppy drives.Need the latest in optical drive support with DVD capacity.
HPE DVD-RW drive - Serial ATA - internal
DVD-RW drive - internal
Serial ATA
Optical Storage
DVD-RW - 5.25" x 1/2H
ProLiant MicroServer, ML10 Entry, ML10 Special, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350p Gen8
Serial ATA
Optical Storage
HPE ProLiant MicroServer, ML10 Entry, ML10 Special, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350p Gen8
