Looking to reduce energy cost and space with increased performance? HP Common Slot Power Supplies share a common electrical and physical design that allows for hot-swap, tool-less installation into HP server and storage solutions. These power supplies are available in multiple, high-efficiency input and output options, allowing you to "right-size" a power supply for specific server/storage configurations and environments. This flexibility helps to reduce power waste, lower overall energy costs, and avoid "trapped" power capacity in the data center. The power supplies provide the IT industry's highest level of power efficiency (up to 96%), helping users to reduce power requirements per server and reducing overall data center power requirements. The Platinum Plus and Titanium power supplies also enable HP Power Discovery Services which focus on increasing compute density while reducing data center outages.
Best in Class Power Supply Technology
HPE Common Slot Power Supplies are designed to simplify the serviceability and maintenance of power supplies across the HPE portfolio of server and storage products by being hot-swappable and providing a tool-less installation.Multiple power management options deliver greater power efficiency when using redundant power supplies to reduce overall power usage.Multiple input and output options deliver increased flexibility in usage while reducing the chances of creating "trapped" power capacity in the data center.HPE Common Slot Power Supplies have Titanium level certification by both the 80Plus program and the EPRI providing the highest level of power efficiency (up to 96%) in the IT industry.Higher-end power supplies offer HPE Power Discovery Services that help customers reduce human error during the installation process, reclaim over-provisioned power capacity in the data center, and accurately measure/monitor power usage.
- HPE Common Slot High Efficiency - power supply - hot-plug - 460 watt
- Power supply - hot-plug - plug-in module
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 100-240 V
- Power Capacity
- 460 watt
- Designed For
- ProLiant DL320 G6, DL320e Gen8, DL360 G7, DL360e Gen8, DL360p Gen8, DL370 G6, DL380 G6, DL380 G7, DL380e Gen8, DL380p Gen8, DL385 G7, DL385p Gen8, DL388p Gen8, ML110 G7, ML30 Gen9, ML310e Gen8, ML350 G6, ML350e Gen8, ML350p Gen8, ML370 G6, SL160z G6, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Power Capacity
- 460 watt
- Efficiency
- 90%+
- 80 PLUS Gold
- Designed For
- HPE ProLiant DL320e Gen8 Base (460 watt), DL320e Gen8 Performance (460 watt), DL360 G7 Special Server (460 watt), DL360e Gen8 (460 watt), DL360e Gen8 Base (460 watt), DL360e Gen8 Entry (460 watt), DL360e Gen8 Performance (460 watt), DL360e Gen8 Special Server (460 watt), DL360p Gen8 (460 watt), DL360p Gen8 Base (460 watt), DL360p Gen8 CMS (460 watt), DL360p Gen8 Entry (460 watt), DL360p Gen8 High Performance (460 watt), DL370 G6 Special Server (460 watt), DL380 G6 (460 watt), DL380 G6 Special Rack Server (460 watt), DL380 G7 Special Server (460 watt), DL380e Gen8 (460 watt), DL380e Gen8 Base (460 watt), DL380e Gen8 Entry (460 watt), DL380e Gen8 High Performance (460 watt), DL380e Gen8 Storage (460 watt), DL380p Gen8 (460 watt), DL380p Gen8 Base (460 watt), DL380p Gen8 Entry (460 watt), DL380p Gen8 High Performance (460 watt), DL380p Gen8 Special (460 watt), DL385p Gen8 (460 watt), DL385p Gen8 Dedicated Workload (460 watt), DL385p Gen8 Entry (460 watt), DL385p Gen8 Maximized Consolidation (460 watt), DL385p Gen8 Storage (460 watt), DL385p Gen8 Storage Centric (460 watt), DL388p Gen8 Base (460 watt), ML110 G7 Base (460 watt), ML110 G7 Performance (460 watt), ML30 Gen9 (460 watt), ML30 Gen9 Base (460 watt), ML30 Gen9 Entry (460 watt), ML30 Gen9 Performance (460 watt), ML30 Gen9 Solution (460 watt), ML310e Gen8 (460 watt), ML310e Gen8 Base (460 watt), ML310e Gen8 Entry (460 watt), ML310e Gen8 Performance (460 watt), ML310e Gen8 v2 (460 watt), ML310e Gen8 v2 Base (460 watt), ML310e Gen8 v2 Enty (460 watt), ML310e Gen8 v2 Performance (460 watt), ML350e Gen8 (460 watt), ML350e Gen8 Base (460 watt), ML350e Gen8 Entry (460 watt), ML350e Gen8 Performance (460 watt), ML350e Gen8 v2 (460 watt), ML350e Gen8 v2 Base (460 watt), ML350p Gen8 (460 watt), ML350p Gen8 Base (460 watt), ML350p Gen8 Entry (460 watt), ML350p Gen8 Performance (460 watt), ML350p Gen8 Special Server (460 watt), ML370 G6 Special Server (460 watt)
