HP Deskjet 1000 - printer - colour - ink-jet
HP Deskjet 1000 Printer - J110a
Quicklinx: 76Y3WS00 Mfr#: CH340B#BEV
Print and share everyday documents with this reliable HP printer. This easy-to-use printer is compact, affordable and helps you conserve resources.
Enjoy easy set-up and reliable performance from a printer you can trust:
- Get started straightaway - easy-to-use and installs right out of the box in just a few minutes.
- No waiting around - this quick-response printer powers up in seconds; save time with instant shut-down too.
- Get peace of mind with the one-year limited warranty plus HP Total Care advice and support.
- Be sure of reliable performance from the world's top-selling printer brand.
Print everyday documents with HP's most straightforward and affordable printer:
- Produce everyday documents with laser-quality text and vivid colour graphics.
- Get great print quality with affordable HP ink cartridges.
- Trust HP Deskjet - celebrating more than 20 years as the world's top-selling printer brand.
- Get more printed pages with optional high-capacity XL ink cartridges (not included, please purchase separately).
Reduce energy consumption and conserve resources - designed with the environment in mind:
- Conserve energy - and save money - with this ENERGY STAR® qualified printer.
- New, low-consumption design cuts energy use in half compared with previous products.
- Save resources - this HP Deskjet printer is made of 30 percent recycled plastics.
- Easily recycle HP Deskjet packaging - this product is shipped in 99% recyclable packaging.
- Get free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly.
Designed with the environment in mind - created from 30% recycled plastic.
Recycle or reuse 99% of packaging - including a reusable bag. - Some small pieces of tape are not recyclable.
Low energy: sleep mode is comparable with powering a clock radio.
ENERGY STAR® qualified product
Box Contains:
- HP Deskjet 1000 Printer
- HP 301 Black Ink Cartridge
- HP 301 Tri-colour Ink Cartridge
- HP software CD
- Setup guide, reference guide
- Power supply and cord
- Reusable bag
  • Enjoy easy set-up and reliable performance from a printer you can trust
    Get started straightaway – easy-to-use and installs right out of the box in just a few minutes.No waiting around – this quick-response printer powers up in seconds; save time with instant shut-down too.Get peace of mind with the one-year limited warranty plus HP Total Care advice and support.Be sure of reliable performance from the world's top-selling printer brand.
  • Print everyday documents with HP's most straightforward and affordable printer
    Produce everyday documents with laser-quality text and vivid colour graphics.Get great print quality with affordable HP ink cartridges.Trust HP Deskjet – celebrating more than 20 years as the world's top-selling printer brand.Get up to 2.5x more black printed pages and 2x more colour printed pages with optional high-capacity ink cartridges.
  • Reduce energy consumption and conserve resources – designed with the environment in mind
    Conserve energy – and save money – with this ENERGY STAR qualified printer.New, low-consumption design cuts energy use in half compared with previous products.Save resources – this HP Deskjet printer is made of 30 percent recycled plastics.Get free, easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.
Printer Type
Personal printer - ink-jet - colour
2 kg
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 16 ppm - black draft - A4 (210 x 297 mm) , Up to 12 ppm - colour draft - A4 (210 x 297 mm) , Up to 5.5 ppm - black best - A4 (210 x 297 mm) , Up to 4 ppm - colour best - A4 (210 x 297 mm)
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
4800 x 1200 dpi
USB
Language Simulation
PCL 3
Media Type
Envelopes, transparencies, labels, iron-on transfers, cards
Total Media Capacity
60 sheets
Monthly Duty Cycle (max)
1000 pages
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
42.1 cm x 38 cm x 26.6 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Print Speed
Wired
USB
600 dpi
4800 x 1200 dpi
Language Simulation
PCL 3
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
75 g/m² - 280 g/m²
60 sheets
Output Trays Capacity
25 sheets
Duty Cycle
1000 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 301 , 1 x ink cartridge (black) - up to 190 pages - HP 301
Power adapter - external
Frequency Required
50/60 Hz
10 Watt
Environmental Standards
ENERGY STAR
5 °C
5 - 80%
42.1 cm
38 cm
26.6 cm
2 kg
76Y3 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.41
