HP DesignJet T630 Large-Format Printer
Quicklinx: GXSNWS00 Mfr#: 5HB11A#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Ink-jet
£1,529.40 ex VAT
£1,835.28 inc VAT
The world's smallest wide-format printer with a built-in stand, is designed to fit your office, budget, and the way you work. Print multi-size projects with ease. Print your A1 plot as fast as 30 seconds. 1 GB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Extreme simplicity
    Print multi-size A3/B and A1/D or A0/E projects automatically, without manually switching the media source. Save time with the world's easiest job submission - send multiple files in one click with HP Click software. Print with confidence you'll get the results you expect with an intuitive driver and true print preview.
  • Fits your office and budget
    Save space with the world's smallest plotters designed to fit your office, including a built-in stand. Use up to 95% less ink for routine maintenance and get up to 100 extra A1/D pages per month. More sustainable design reduces CO2e up to 7.3tons/year by units sold by using up to 30%recycled plast
HP DesignJet T630 - large-format printer - colour - ink-jet
Printer Type
36" large-format printer - ink-jet - colour
34.7 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
914 mm x 45.7 m
Print Speed
Up to 0.5 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - black draft - A1 (594 x 841 mm) , Up to 0.5 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, LAN, Wi-Fi
RAM Installed (Max)
1 GB (1 GB)
Language Simulation
HP RTL, CALS G4, HP GL/2, URF, JPEG
Media Type
Plain paper, photo paper, bond paper, recycled paper, film, glossy paper
Print server
Printer Features
Print from mobile device, 6.2 kg max roll weight
Environmental Standards
EPEAT Gold
1-year warranty
131.7 cm x 60.5 cm x 93.2 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Minimum Ink Droplet Size
12 pl (black), 5.5 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, pigment black)
Print Speed
Wireless
USB 2.0, LAN, Wi-Fi
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Printer Features
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
914 mm x 45.7 m
Media Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
Media Thickness Range
Up to 0.3 mm
Media Weight
60 g/m² - 280 g/m²
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
FCC Class B certified, CSA, ICES Class B, WEEE, ERP
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
2.1 Watt
Software Included
HP Support Assistant, HP Click, HP DesignJet Utility
EPEAT Compliant
EPEAT Gold
ENERGY STAR
Limited warranty - parts - 1 year
5 °C
20 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
42 dBA
131.7 cm
60.5 cm
93.2 cm
34.7 kg
Width (Shipping)
147 cm
Depth (Shipping)
57.5 cm
Height (Shipping)
59 cm
Weight (Shipping)
55.3 kg
GXSN HP Care Pack Installation Service - Installation / Configuration In Stock £375.11
Type: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: Roll (91.4 cm x 45.7 m)
Max Paper Size: ANSI D (559 x 864 mm)
Max Paper Size: A0 (841 x 1189 mm)
Brand: HP
Price Range Ex VAT: £1500+
