HP Colour LaserJet Pro M177fw Multifunction Printer
Quicklinx: 9FXSWS00 Mfr#: CZ165A#B19
Ideal for businesses that want to boost productivity and print professional-quality marketing materials without leaving the office. This networked HP Color LaserJet Pro MFP prints, copies and scans in vibrant colour.
  • Fit this compact, colour MFP in small spaces, and finish print jobs in fewer steps
    Get brilliant, consistent colour using Original HP LaserJet print cartridges, and print crisp text at the same black cost-per-page as from a black-and-white HP LaserJet.Handle big copy jobs with the 35-page automatic document feeder, while you work on other business.Expand your media options with support for a wide variety of media types.Speed through document tasks: get the first print out in a matter of seconds. Set the pace for success with an MFP that prints, copies, scans and faxes fast.
  • Easy control at your fingertips
    Set up each task with just a few simple taps on the 7.6 cm colour touchscreen, and access apps that make document management easier.Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Help save energy with HP Auto-On/Auto-Off Technology – intelligence that can turn your printer on when you need it and off when you don't.
  • Print on your terms
    Print from virtually anywhere using your smartphone, tablet, and PC – with HP ePrint and Apple AirPrint.Extend your printing reach. Easily set up, print, and share using built-in Ethernet and wireless connectivity.Easily manage your MFP with convenient device management tools.
HP Color LaserJet Pro MFP M177fw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
250 - 950 pages
Max Copying Speed
Up to 16 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 400 dpi (colour)
Max Printing Speed
Up to 17 ppm (mono) / up to 4 ppm (colour)
Max Printing Resolution
Up to 2400 dpi (mono) / up to 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning
1200 x 1200 dpi
Display
3"
Original Size
Legal (216 x 356 mm) (max)
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper, film, glossy paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to application
AC 230 V (50/60Hz)
42.3 cm x 42.5 cm x 33.5 cm
16 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
20000 pages
250 - 950 pages
Display Diagonal Size
3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL
Image Enhancement Technology
HP ImageREt 2400
First Print Out Time B/W
16 sec
First Print Out Time Colour
27.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Speed
Up to 20 ppm
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling
Document & Media Handling
Max Original Size
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
150 sheets
50 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 150 sheets - Legal (216 x 356 mm) , Output tray - 50 sheets
Speed Details
Printing: up to 17 ppm (Letter A) - B/W , Printing: up to 4 ppm (Letter A) - colour , Printing: up to 16 ppm (A4) - B/W , Printing: up to 4 ppm (A4) - colour , Copying: up to 17 ppm (Letter A) - B/W , Copying: up to 4 ppm (Letter A) - colour , Copying: up to 16 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour , Scanning: up to 7.5 ipm - B/W , Scanning: up to 5.5 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA, WPA2
Operating System Support
Linux, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, MS Windows Server 2008 R2 SP1
Software Included
Drivers & Utilities, Readiris
AC 230 V (50/60Hz)
290 Watt
Power Consumption Standby
9.2 Watt
Power Consumption Sleep
1.3 Watt
First Copy Out Time B/W
15 sec
First Copy Out Time Colour
28 sec
USB cable, phone cable
Consumables Included
1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
UL, cUL, GS, ICES-003, EN55024, CISPR 22, EN55022 Class B, EMC, Laser Class 1, IEC 60950-1, FCC CFR47 Part 15 B, EN 60825-1, GB 17625.1, Directive 2004/108/EC, GB 9254-2008, Directive 2006/95/EC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006, IEC 60825-1:2007
ENERGY STAR Certified
Limited warranty - 1 year
42.3 cm
42.5 cm
33.5 cm
16 kg
Shipping Width
59.8 cm
Shipping Depth
46.4 cm
Shipping Height
39.8 cm
Shipping Weight
19.6 kg
Sound Emission
53 dBA (operating)
15 °C
30 °C
10 - 80%
9FXS HP 130A Black LaserJet Toner Cartridge In Stock £49.74
9FXS HP 130A Cyan LaserJet Toner Cartridge In Stock £51.31
9FXS HP 130A Yellow LaserJet Toner Cartridge In Stock £51.31
