Impress with colour and increase efficiency. Get high-quality colour and fast two-sided print speeds. Save time with Smart Task shortcuts in HP Smart app, and print and scan from your phone. Get seamless connections and strong security solutions.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Best-in-class mobile print app
Get easy printing and scanning from your mobile device, with HP Smart. -
Automate scanning tasks and save time
Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks in HP Smart app. -
Powerful printing. Energy smart
Count on high-quality colour and peak printing performance with Original HP Toner cartridges with JetIntelligence. -
Automatic two-sided printing
Speed through multipage documents with automatic two-sided printing. -
The right touch for business tasks
Easily manage tasks at the device with an intuitive touchscreen.
- HP Color LaserJet Pro M255dw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- Number of Users
- 1-5 users
- 14.8 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 22 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm) , Up to 22 ppm - colour normal - ANSI A (Letter) (216 x 279 mm) , Up to 12 ppm - duplex - A4 (210 x 297 mm) , Up to 13 ipm - duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Image Enhancement Technology
- HP ImageREt 3600
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Flash Memory Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF, PCLm, URF, PWG
- Media Type
- Envelopes, transparencies, labels, plain paper, photo paper, bond paper, recycled paper, brochure paper, card stock, light-weight paper, preprinted paper, glossy paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, priority feed tray
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 150 - 2500 pages
- Networking
- Print server
- Printer Features
- Instant-on Technology
- System Requirements
- SunSoft Solaris 8, HP-UX 11, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, SuSE Linux 11, Debian GNU/Linux 5.0, Red Hat Enterprise Linux 5, SuSE Linux 10.3, Android, Ubuntu 8.04, Microsoft Windows Vista (32/64 bits), Ubuntu 9.10, Debian GNU/Linux 5.0.1, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Red Hat Fedora 11, Red Hat Fedora 12, Apple MacOS X Lion 10.7, Apple iOS, SuSE Linux 11.1, SuSE Linux 11.2, Ubuntu 8.04.1, Ubuntu 8.04.2, Debian GNU/Linux 5.0.2, Debian GNU/Linux 5.0.3, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8 Enterprise (32/64 bits), Windows 8 Pro (32/64 bits), Oracle Solaris 9, Apple OS X 10.9 Mavericks, Microsoft Windows RT 8, Windows 8 Enterprise N (32/64 bits), Linux 9.4, Linux 9.5
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 39.2 cm x 41.9 cm x 24.75 cm
- Printer Type
- Number of Users
- 1-5 users
- Localisation
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- HP ImageREt 3600
- PostScript Support
- Standard
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 12.2 sec
- Fonts Included
- 84 x TrueType
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 256 MB (max)
Flash Memory
- Flash Memory
- 256 MB (installed) / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 40000 pages
- 150 - 2500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, HTTP, HTTPS, SLP
- Apple Bonjour, WEP, WPA, WPA2, 802.1x, TKIP, AES, WPS, Wi-Fi Direct, IPv6 support
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- IEC 60950-1, FCC CFR47 Part 15 B, EN 62479:2010, EN 61000-3-3:2013, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 55024:2010+A1:2015, EN 55032:2012, ICES-003 issue 6, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, CISPR 32:2012, EN 60825-1:2014, IEC 60825-1:2014, CISPR 32:2015, EN 55032:2015+AC:2016 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 337 Watt
- Power Consumption Stand by
- 7.2 Watt
- Power Consumption Sleep
- 0.8 Watt
- Software Included
- Drivers & Utilities
- OS Required
- EPEAT Compliant
- EPEAT Silver
- Blue Angel
- ENERGY STAR
- Limited warranty - parts - 1 year
- 10 °C
- 32.5 °C
- 10 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 50 dBA
- 39.2 cm
- 41.9 cm
- 24.75 cm
- 14.8 kg
- Width (Shipping)
- 49.8 cm
- Depth (Shipping)
- 29.8 cm
- Height (Shipping)
- 51 cm
- Weight (Shipping)
- 17.4 kg
Ink (6)
HP 207A Yellow Original LaserJet Toner Cartridge | In Stock | £60.86 |
HP 207A Magenta Original LaserJet Toner Cartridge | In Stock | £59.07 |
HP 207X High Yield Cyan Original LaserJet Toner Cartridge | In Stock | £82.84 |
HP 207X High Yield Yellow Original LaserJet Toner Cartridge | In Stock | £80.32 |
HP 207X High Yield Magenta Original LaserJet Toner Cartridge | In Stock | £80.32 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
