Affordable, business-enhancing colour from an HP LaserJet that's easy to manage and use. Produce professional-quality colour marketing materials and more. Maximise your investment with expandability options. Count on HP for energy-saving features.
Make your business look its best with high-performance colour
Create marketing materials with realistic colour and crisp detail thanks to PANTONE colour matching and HP Easy Color.Increase colour accuracy with HP ImageREt 3600 and HP ColorSphere toner technology.Achieve low-cost, high-quality printing right out of the box, with a complete set of cartridges – on average, nearly two times more black toner and more than two times the colour toner of leading competitors.Print black text affordably, using an optional high-capacity black print cartridge,. -
Invest in a printer that's as easy to use as it is to manage
Manage jobs directly from the printer's four-line colour control panel, and easily print from a USB flash drive.Make printing as mobile as you are with HP ePrint – now you can print from virtually anywhere.Keep confidential information secure by requiring a PIN to retrieve print jobs and protect data with the HP High-Performance Secure Hard Disk.Easily control colour usage with HP Color Access Control, and proactively manage printing environments with industry-leading HP Web Jetadmin. -
Take advantage of inventive expandability options
Easily update, manage and extend printer capabilities, using HP FutureSmart Firmware.Take advantage of the HP Solutions Business Partners programme, enabling you to access HP certified solutions from industry-leading partners.Incorporate optional productivity and security solutions easily, using the hardware integration pocket,.Improve productivity: this workhorse colour laser printer gives you up to 1,100-sheet capacity to save time and complete large print jobs without reloading. -
Enjoy outstanding energy and paper savings
Reduce energy use by 19% to 66% by setting the Auto-On/Auto-Off mode. Save even more energy with Instant-on Technology which speeds warm-up and cool-down times.Save time with convenient cartridge installation, and get free, easy cartridge recycling.Conserve resources and get up to 50% paper-savings using automatic two-sided printing.
- HP LaserJet Enterprise 500 M551n - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 34 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 32 ppm - B/W - A4 (210 x 297 mm) , Up to 32 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Interface
- USB, Gigabit LAN
- Processor
- ARM Cortex-A8 800 MHz
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, cards, heavy-weight glossy paper, bond paper, recycled paper, opaque film, glossy paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1500 - 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Server 2003 SP1 or later, Microsoft Windows Server 2008, Apple MacOS X 10.5
- Microsoft Certification
- Compatible with Windows 7
- 51.4 cm x 49.1 cm x 38.5 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 1200 dpi
- 1200 dpi
- PostScript Support
- Included
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 11 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Media Handling
- Processor
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm, 101.6 x 148.6 mm, 215.9 x 296.9 mm
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - 215.9 x 296.9 mm
- Max Media Capacity
- 1100 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- 1500 - 5000 pages
- Networking
- Print server
- Data Link Protocol
- ICMP/IP, IPSec, LPR/LPD, FTP, BOOTP, DHCP, Bonjour, SLP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP
- Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 5500 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
- FCC Class B certified, UL, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EMC, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 605 watt
- Power Consumption Stand by / Sleep
- 6.9 watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows XP/Vista/7/2003/2008 - HD 200 MB , MacOS X 10.5/10.6 - HD 150 MB
- 10 °C
- 30 °C
- 10 - 70%
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 52 dBA
- 51.4 cm
- 49.1 cm
- 38.5 cm
- 34 kg
- Width (Shipping)
- 72.5 cm
- Depth (Shipping)
- 60 cm
- Height (Shipping)
- 50 cm
- Weight (Shipping)
- 37.7 kg
