HP Coated Paper-610 mm x 45.7 m (24in x 150ft)
Quicklinx: D80WS00 Mfr#: C6019B
Type: [N/A]
Technology: Ink-Jet
Hurry, only 1 left in stock!
£29.82 ex VAT
£35.78 inc VAT
Roll or stack your time-sensitive documents right off the printer. Ideal for colour-accurate everyday prints, working comps and design proofs, this PEFC certified paper is easy to handle and provides high-quality, consistent results.
HP - paper - matte - 1 roll(s) - Roll (61 cm x 45.7 m) - 90 g/m²
Paper
Product Material
Wood fibre
Surface Finish
Matte
Coating
Coated
Media Size
Printing Technology
Ink-jet
Media Weight
90 g/m² / 24 lbs
Media Thickness
4.5 mil
Media Brightness
89
Media Whiteness
145
Included Qty
1 roll(s)
Compatible with
DesignJet 100, 10XX, 11X, 120, 130, 2800, 3800, 40XX, 430, 45XX, 488, 500, 5000, 510, 5100, 5500, 75X, 800, 815, 820, 9000, L26500, T1100, T1120, T120, T1200, T1300, T1500, T2300, T520, T610, T620, T7100, T770, T790, T920, Z2100, Z3100, Z3200, Z5200, Z6100, Z6200; Designjet Copier cc800; Deskjet 350
Dimensions (WxDxH) / Weight
2.62 kg
Shipping Width
11.1 cm
Shipping Depth
11.1 cm
Shipping Height
65.1 cm
Shipping Weight
3.18 kg
Media
Media Type
Paper
Product Material
Wood fibre
Surface Finish
Matte
Coating
Coated
Media Sizes
Printing Technology
Ink-jet
Media Thickness
4.5 mil
Roll Core Diameter
50.8 mm
Media Brightness
89
Media Whiteness
145
Included Qty
1 roll(s)
Media Weight
90 g/m² / 24 lbs
Colour Category
White
Compatible with
HP DesignJet 100, 100plus, 1050c, 1050c plus, 1055cm, 1055cm plus, 110, 110Plus, 110Plus nr, 110Plus r, 111, 120, 120nr, 130, 130gp, 130nr, 130r, 2000cp, 2500cp, 2800cp, 3000cp, 330, 3500cp, 350c, 3800cp, 4000, 4000ps, 4020, 4020ps, 430, 430d, 4500, 4500mfp, 4500ps, 450c, 4520, 4520 HD-MFP, 4520ps, 455ca, 488ca, 500, 500 Plus, 5000, 5000ps, 5000ps uv, 5000uv, 500ps, 500ps Plus, 510, 5100, 510ps, 5500, 5500 uv, 5500mfp, 5500ps, 5500ps uv, 700, 750c, 750c plus, 755cm, 800, 800ps, 815mfp, 820 MFP, 9000s, L26500, T1100, T1100 MFP, T1100ps, T1120, T1120 HD-MFP, T1120 SD-MFP, T1120ps, T120, T120 ePrinter, T1200, T1200 HD-MFP, T1200ps, T1300 ePrinter, T1300 PostScript ePrinter, T1500 ePrinter, T1500 PostScript ePrinter, T2300 eMultifunction Printer, T2300 PostScript eMultifunction Printer, T520 ePrinter, T610, T620, T7100, T770, T770 Hard Disk Version, T790 ePrinter, T790ps ePrinter, T920 ePrinter, T920 PostScript ePrinter, Z2100, Z2100 GP, Z3100, Z3100 GP, Z3100ps GP, Z3200, Z3200ps, Z5200 PostScript, Z6100, Z6100ps, Z6200 , HP Designjet Copier cc800ps , HP Deskjet 350c
Type: [N/A]
Technology: Ink-Jet
Brand: HP
