HPE 4GB MEM 2RX8 PC3-10600E UDIMM
GREAT VALUE ADDITIONAL MEMORY
Quicklinx: 71DZWS00 Mfr#: 500672-B21
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
  • High Performance
    HPE DDR3 SmartMemory performs to industry-defined specifications.HPE DDR3 SmartMemory has been tested and performance-tuned specifically for HPE ProLiant Server series, which ensures that HPE server memory is optimized for every HPE server.HPE DDR3 SmartMemory enables extended memory performance features through the system ROM.
  • High Reliability
    HPE DDR3 SmartMemory is made of the highest quality materials, reducing issues that affect signal integrity and increasing system reliability.
  • Improved Efficiency
    HPE DDR3 SmartMemory supports HPE servers at a lower price point.
HPE - DDR3 - module - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Dual rank, unbuffered
Voltage
1.5 V
HP 500672-B21, HP 501541-001
ProLiant BL280c G6, BL2x220c G6, BL2x220c G7, BL460c G7, BL490c G7, DL120 G6, DL120 G7, DL160 G6, DL160se G6, DL180 G6, DL2x170h G6, DL320 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL4x170h G6, MicroServer, ML110 G6, ML110 G7, ML330 G6, SL160z G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Voltage
1.5 V
HPE ProLiant BL280c G6, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL2x220c G7, BL460c G6, BL460c G7, BL490c G6, BL490c G7, DL120 G6, DL120 G6 Base, DL120 G6 Entry, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL180 G6, DL180 G6 Special Server, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Efficiency, DL360 G7, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL370 G6, DL370 G6 Special Server, DL380 G6, DL380 G6 High Efficiency, DL380 G7, DL380 G7 Efficiency, DL380 G7 Special Server, DL4x170h G6, MicroServer, ML110 G6, ML110 G6 Base, ML110 G6 Entry, ML110 G6 Performance, ML110 G6 Special Server, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML350 G6, ML350 G6 Base, ML370 G6, SL160z G6, SL170z G6, SL2x170z G6, SL390s G7, WS460c G6 Workstation
