Create high-quality colour photos and everyday documents with low-cost Original HP ink cartridges. These dependable cartridges deliver consistent results, so you can print vivid colour and crisp text for the life of your cartridge.
Designed to work the first time, every time
Be assured that HP Original Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with HP Original Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – HP Original Cartridges designed with the planet in mind for easy recycling and less waste. -
Better together. Better results
HP Original Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance. -
Vivid colors and crisp text
Make eye-catching documents with HP ink cartridges-designed to deliver vivid color and crisp, sharp text. -
Active Ink Balancing for full colour ink usage
Performance you can count on – produce high-quality documents throughout the life of your colour cartridge.
- HP 304 - black - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black
- Yield
- Up to 120 pages ISO/IEC 24711
- Localisation
- Western Europe
- Compatible with
- AMP 130; Deskjet 2620, 2621, 2622, 2624, 2630, 2632, 2633, 2634, 2640, 2652, 3720, 3721, 3722, 3723, 3730, 3732, 3733, 3735, 3750, 3752, 3758, 3760, 3762, 3764; ENVY 5010, 5014, 5020, 5030, 5032, 5052, 5055, 5070
- Shipping Width
- 11.3 cm
- Shipping Depth
- 3.7 cm
- Shipping Height
- 11.5 cm
- Shipping Weight
- 50 g
- Localisation
- Western Europe
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Black
- Included Qty
- 1-pack
- Yield
- Compatible with
- HP AMP 130 , HP Deskjet 2620, 2621, 2622, 2624, 2630, 2632, 2633, 2634, 2640, 2652, 3720, 3721, 3722, 3723, 3730, 3732, 3733, 3735, 3750, 3752, 3758, 3760, 3762, 3764 , HP ENVY 5010, 5014, 5020, 5030, 5032, 5052, 5055, 5070
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
F981 048552 Condition: Damaged stock - Item is new but has packaging damage |
£7.69 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
