Genuine HPE 2GB PC2-3200 DDR2 400MHz 240-pin SDRAM Memory Stick
Specifications:
Category: Proliant Memory
Sub-Category: PC2-3200
Generation: 400MHz
Technology: DDR2 SDRAM
Capacity: 2GB
Form Factor: DIMM 240-pin
- Integral - DDR - module - 2 GB - DIMM 184-PIN - 400 MHz / PC3200 - registered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR SDRAM - DIMM 184-PIN
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Dual rank, registered
- Voltage
- 2.5 V
- Limited lifetime warranty
- Designed For
- HPE ProLiant DL380 G4, DL380 G4 High Performance, DL580 G3, DL580 G3 High Performance, ML350 G4p, ML370 G4, ML370 G4 High Performance, ML570 G3, ML570 G3 High Performance, ML570 G4, ML570 G4 High Performance
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR SDRAM
- Form Factor
- DIMM 184-PIN
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- ECC
- Module Configuration
- 256 x 72
- Chips Organization
- 128 x 4
- Voltage
- 2.5 V
- Compatible Slots
- 1 x memory - DIMM 184-PIN
- Designed For
