HP 276DW OfficeJet Pro Colour InkJet Multifunction Printer
Quicklinx: 8MX9WS00 Mfr#: CR770A#A80
Manage your print environment – and budget – with this advanced, network-ready MFP and get up to 50% lower cost per page than lasers. Enjoy easy integration into your office workflow with efficient management and security controls.
  • Save time, streamline workflows and simplify office tasks
    Access print tools and useful business apps via the intuitive control panel and large colour touchscreen.Handle large jobs with automatic two-sided printing, copying and scanning – load up to 500 sheets at once with the optional paper tray.Print up to 2,300 black pages – or up to 1,500 colour pages – from a single high capacity Original HP cartridge.Choose HP for reliable workgroup printing – designed for volumes of up to 1,500 pages a month.
  • Conserve resources without sacrificing performance
    Use up to 50% less energy than colour lasers – set your printer for savings with Schedule On and Schedule Off.Save up to 50% on paper with automatic two-sided printing.Use up to 50% less supplies and packaging by weight compared with colour laser.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
HP Officejet Pro 276dw MFP - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 impressions
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 12 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
4800 x 4800 dpi
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, greeting cards, photo paper, thick paper, card stock, glossy photo paper, matte photo paper, tri-fold paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to folder, save to network folder
AC 110/230 V (50/60Hz)
49.4 cm x 46 cm x 31.5 cm
12.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 impressions
250 - 1500 pages
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF
Automatic Duplexing
First Print Out Time B/W
13 sec
First Print Out Time Colour
14 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
4800 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
48 stations
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
250 sheets
Max Media Capacity
500 sheets
150 sheets
Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 150 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Printing: up to 20 ppm - B/W (ISO) , Printing: up to 15 ppm - colour (ISO) , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 12 ppm - colour (ISO)
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, LEAP, TLS, 802.1x
Operating System Support
Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities, HP ePrint Wireless Direct
35.09 Watt
Power Consumption Standby
7.11 Watt
Power Consumption Sleep
1.63 Watt
ETSI, GOST, RoHS, REACH, LVD
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
49.4 cm
46 cm
31.5 cm
12.7 kg
Shipping Width
56.7 cm
Shipping Depth
38 cm
Shipping Height
52 cm
Shipping Weight
18.2 kg
Sound Emission
62 dBA (operating)
15 °C
30 °C
15 - 80%
Ink (2)
8MX9 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
8MX9 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
Other bundles (2)
8MX9 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
8MX9 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £18.74
