HP 2004 Standard Keyboard USB 7F
HP USB Standard Keyboard
Customer rating: 5.0* (Write a review)
Quicklinx: 3BHLWS00 Mfr#: DT528A
This high-quality and affordable keyboard features a standard layout and a whole host of user-friendly functions.
HPE Standard - keyboard - silver, carbonite Input Device
Keyboard
USB
Wired
Spillproof
Silver, carbonite
45.8 cm x 16.3 cm x 2.5 cm
0.9 kg
1-year warranty
Keyboard
USB
Keyboard Technology
Membrane
Spillproof
45.8 cm
16.3 cm
2.5 cm
0.9 kg
1 x USB - 4 pin USB Type A
Silver, carbonite
1 x USB cable - 1.8 m
FCC Class B certified, CSA, UL, TUV, ANSI-HFS-100, TUV GS, VCCI, ISO 9241-4, C-Tick, BSMI, PC 99, MIC
Microsoft Windows 2000 / XP
Limited warranty - 1 year
10 °C
50 °C
10 - 90%
Sound Emission
43 dBA
Customer reviews
Write a review for the HP 2004 Standard Keyboard USB 7F here!
Excellent vaule quailty keyboard
Reviewed by Paul Robins. Review Posted 03/12/2009
I've bought a few dozen of these over the past two years. All still working 100%. Excellent value for a properly made USB keyboard that is good to type on and has no frilly bits. Always found within 45 seconds first time round by PCs old and new and instantly there-after. Buy one before they go and change it.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Superb, solid no-frills keyboard for heavy-duty use.
Reviewed by Anonymous Review Posted 20/03/2009
So far this is probably the best keyboard I have ever come across, ideal if you're a fast typist in need of a rock-solid yet super-comfortable keyboard.
  • Overall 5*
  • Ease of use 5*
Exactly what I wanted
Reviewed by John Stevens. Review Posted 21/03/2008
This is a solid, no-frills keyboard which looks smart and works well. The keys are quiet and feel positive. The keyboard is comfortable to use, with 3 height options at the back and the keys well spaced. Conventional qwerty layout and number pad plus 'F' keys - note that there are no extra 'hotkeys', coldkeys, bells or whistles.
  • Overall 5*
  • Ease of use 5*
Read all 4 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
